Need help with this SDCE pulley.
Old Dec 8, 2006 | 12:15 AM
BigBenz's Avatar
Default Need help with this SDCE pulley.
Ok i know were to get the bracket crap o need. But i have no idea what size bolt(s) i need for the pulley. The pulley is a sdce 7.250 8 rib harmonic balance pulley. All i need to know is what size bolt(s) i need to the pulley.
If you know were i can buy it from let me know i was just plannin on getting the size and getting it from summit. This kit is for a d1sc ls1 2000 z28.
Stupid question time.
Do i need bolts for the 3 little holes in the pulley.
Thanks guys.
Old Dec 8, 2006 | 12:35 PM
onefastss223's Avatar
The 3 holes in the crank pulley are so you can bolt it to the ATI Damper that you need to run with the SDCE system.
BTW, where is the adjustable tensioner that sits on top of the bracket?(SDCE supplied)
Old Dec 8, 2006 | 01:46 PM
BOONE's Avatar
The tensioner will run approx 160.00 shipped.
Old Dec 10, 2006 | 06:05 PM
BigBenz's Avatar
yea i got the extra pulley. thanks for responding. I was getting mad trying to figure it out.
Old Dec 11, 2006 | 08:01 PM
BigBenz's Avatar
I was wondering if any of yall have the size of the bolt im gonna need with the ATI balancer and this pulley? Also can i just use any bolts that fit for the 3 small holes?
thanks alot guys.
Old Dec 11, 2006 | 08:28 PM
Jake@EPP's Avatar
The ATI balancer should come with necessary hardware for installation of the pulley, if not just contact ATI to get correct pitch and size for the bolts. We do sell this pulley on our site, give me a call if your interested.
Old Dec 11, 2006 | 08:51 PM
NA$TY-TA's Avatar
thanks alot guys.
I guess the real questions to ask is....
did you buy this kit 2nd hand???
If so do you even have a ATI Balancer.... not ATI Procharger.... ATI the superdampner balancer people.
If not you need to buy it to work with this kit. There about $450.
I have ton's of install pic's from back when i had one...... before i switched to Turbo.
Kyle
Old Dec 11, 2006 | 10:17 PM
BigBenz's Avatar
im rudy. i was talking to you about the set up. Im sure ill be calling you on the 21st to order my pulley and gauge pod and a few more things. I figure i should just make one large order then waste money on a bunch of small ones.
Old Dec 12, 2006 | 07:12 AM
Jake@EPP's Avatar
Sounds good!
