How much boost on forged 10:1 compression motor?
Lets say you use a 232/238 Cam ,you should only need 10lbs of boost which is fine on the 10-1 comp. Your biggest problem will be the fuel system. The Racetronix single will not be enough.
I would just do dual intanks which should handle 700rwhp easilly enough.
Or a methenol kit.
Or a methenol kit.
