98 block safe for boost
Old Dec 13, 2006 | 09:24 PM
B18CYA's Avatar
Default 98 block safe for boost
looking into building my 98 ls1 for 12-15 psi
would like to keep the cost of the short block down use my block and crank
Old Dec 13, 2006 | 09:30 PM
MiaSSmaro98's Avatar
with no problem look at my sig
Old Dec 13, 2006 | 09:39 PM
B18CYA's Avatar
any running examples?
the 98 blocks have thinner sleeves but not looking to overbore just hold some boost
Old Dec 13, 2006 | 09:48 PM
Spade's Avatar
I am in the same predicament. I am getting ready to forge my 98 but I am not sure if I will want to re-use my old block. I am trying to keep the costs down as well. I have though about just getting a 6.0L iron block and calling it a day but dont know if I want that extra weight.
Old Dec 13, 2006 | 10:00 PM
B18CYA's Avatar
i would rather find a newer ls1 or look into ls2 6.0 before i went iron
im sure there are many with these older blocks runnin boost but would just like some opinions
Old Dec 14, 2006 | 03:47 PM
B18CYA's Avatar
someone out there has to running boost on one of these older block ????????
Old Dec 14, 2006 | 03:58 PM
SuperZ's Avatar
You can look at some of my posts on my build.I machined and build my stock 98 block with forged stuff and now Im running 14psi on a Mid frame turbo with some nitrous from time to time.I dunno what power Im making but enough to beat 1000cc bikes and run just ahead of a formula with 779 rwhp
Old Dec 14, 2006 | 04:17 PM
B18CYA's Avatar
thats what i like to hear
thanks
Old Dec 14, 2006 | 05:19 PM
KHShapiro's Avatar
the block isnt a problem and really neither is the crank, just use good rods , bolts and pistons.
Old Dec 14, 2006 | 06:09 PM
NA$TY-TA's Avatar
what heads....?? please dont tell me 98 heads...... been there, destroyed them......
Old Dec 14, 2006 | 11:57 PM
im gonna sell my 98 shortblock soon and put in a newer block either iron or aluminum
Old Dec 15, 2006 | 01:11 AM
B18CYA's Avatar
what do you mean detroyed them?
i have a very nice set of ported 98 heads i plan on using
Old Dec 15, 2006 | 02:43 AM
SuperZ's Avatar
Mine are unported 98 stock heads with a valve job.I havnt had any prolems but my next one will be a iron block.Not sure on the stroke yet.
Old Dec 15, 2006 | 07:10 AM
kp's Avatar
kp
I put 250 + passes, most in the 9s, 12-14psi on a 98 block, stock connecting rods w/arp bolts and ported 98 heads with stock valves and even graphite head gaskets. Engine is still running fine in a n/a head/cam car.
Keep it safe with a good tune and I doubt you will have any problems, guys that are hurting blocks are making a ton of power or have bad tunes. I have seen the later blocks split cylinders as well as the early blocks so I'm sure its possible to get a 'bad' one no matter what the year.
Old Dec 15, 2006 | 07:27 AM
thats makes me trust mines a bit more
Old Dec 19, 2006 | 05:30 PM
MawneeC5's Avatar
This thread made me feel all warm inside
Old Dec 19, 2006 | 05:46 PM
NassyVette's Avatar
LoL same here...
Old Dec 19, 2006 | 08:57 PM
Dustin 98TA's Avatar
Mine is doing fine so far, Im only running 8 psi and dynoed 500RWHP through the unlocked 4l60. I built the motor to run 14-15 psi, but ATI sent the wrong pulley with the kit. I have a smaller pulley to put on, I just have to find time to put it on and get back to the dyno to retune. Click the link in my sig for details.
