New Setup Update
Old Dec 28, 2006 | 10:42 PM
  #41
Inspector12's Avatar
TT-TECH Veteran
Originally Posted by BLWNZ
Were did you get the header studs, or what kind are they?
ARP Stainless Header studs Summit ,Jegs, I am sure some sponsers cary thim like Thunder racing etc... LS2Camaro-750 800 whos counting the little stuff lol! No really it isn't just the tubo that decides what power you wll be able to make there are a number of factors so I am trying to be realistic instead of saying I am goin to make 1500rwhp its just not realistic.
Old Dec 29, 2006 | 01:44 AM
  #42
JMBLOWNWS6's Avatar
Hurry up and finish monkey. Ive known about this setup for a while and I am waiting for the results. Because I am going to copy you! LOL 3 bar SD? Let me know
Old Dec 29, 2006 | 02:40 AM
  #43
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Is this Textralia triple disk something out now or is it an one off sort of thing?
Looks interesting. Keep us updated and get some more pictures.
Old Dec 29, 2006 | 04:14 AM
  #44
JMBLOWNWS6's Avatar
Na members lurking around with 1k to the wheels allready have it
Old Dec 29, 2006 | 04:36 AM
  #45
bad95killer's Avatar
And how does it feel cause i know the triple disk from any brands are so hard on the leg esp. in traffic or this thing has something different ?!
peace
Old Dec 29, 2006 | 05:13 AM
  #46
TT-TECH Veteran
peace
The feel is like stock on the leg. I could go with a few other clutches that will hold the power, but I was looking for the drivability factor since I drive this on the street primaraly. JM- Brother I am working 7-12's and I have been working on this just about every night finished the drivers side last night and ran all my oil feed lines and water cooling lines for the turbos. Am about to bolt it up the K-member and start assyembling the accessories and wiring tonight. I still have to wait on the clutch till next week according to Jarrod at Textrailia.
Old Dec 29, 2006 | 12:03 PM
  #47
SSilverSSurfer's Avatar
DJ99SS has one but had been having problems with it
Old Dec 29, 2006 | 07:01 PM
  #48
JMBLOWNWS6's Avatar
Awesome man! Jarrod and Peter are awesome vendors. Working on becoming a dealer of there products. It takes forever for the clutches to come to the US then they have to do there machining and balancing. It will be worth it Jeff! Ill make a special trip to see you car up and running when it is done. Im finally caught up on all my work here Have a happy new year and best wishes to your family. Ive been working 8 days striaght 12's So I know what you mean
Old Dec 29, 2006 | 07:39 PM
  #49
todd4168's Avatar
jeff any pics of the incon kit that you want to trade me even for my vortech kit, just kidding. But really any pics?
Old Dec 29, 2006 | 09:31 PM
  #50
TT-TECH Veteran
I have the ones from when I purchased it. take a look as they are not that good I would take some better ones if some people are intersted.
Old Dec 29, 2006 | 10:19 PM
  #51
Got Me SOM's Avatar
a little dusty n dirty those parts are.
yes i am speaking like yoda right now.
Old Dec 29, 2006 | 11:28 PM
  #52
99Z28LS1's Avatar
this is such a gorgeous car, and now after he's done with the turbo stuff he can tell all the other non FI people the difference between turbos and s/c. but he already knew that from what i can make of it
+1000
Old Dec 30, 2006 | 12:00 AM
  #53
disassembled's Avatar
Hey I don't mean to throw a wrench into your operation but I suggest removing those exhaust studs and going with stock bolts. I have a CAS TT setup and Z28 and i cannot pull or insert the manifolds with the studs installed. The problem is when the heads expand/contract it could make the bolts too tight to turn with that tiny allen wrench. This was a MF'r of a time when i had to repair a cracked manifold and i had to remove the manifold. If you can remove and install the manifolds with the bolts in the head then you have nothing to worry about but I don't see you having enough room. Just a little bit of preventive maintenance incase you run into some cracking down the line.
BTW this is an awesome looking kit which reminds me much of my CAS kit with many tweaks and refinements to make it the kit it should have been. I wish you the best of luck with it.
I wish this would have been available last year when i put my car together. I guess i will just have to make due with what i have when i return to the states. I remember when I was one of the few with an actual RUNNING TT car of the CAS style but now it seems everyone and their mothers is on the bandwagon. I still have my glory!
Old Dec 30, 2006 | 12:57 AM
  #54
kickassT/A's Avatar
looks like 3.08 and 3.42 are the only ratios available... no 3.23
Old Dec 30, 2006 | 07:16 PM
  #55
TT-TECH Veteran
I'll address that is it comes to that I appreciate the heads up though. I had already though about that so I am prepared for what ever might come at me. I just didn't get much penitration with the stock bolts with the gaskets while it may have been fine I just needed a little more and I know I could have got some longer bolts I just was wanting to try the studs for a change Antiseiz (sp?)is your friend.
Old Dec 30, 2006 | 07:17 PM
  #56
TT-TECH Veteran
Yeah they look it in the pictures he sent ,but in reality they are very clean.
