STS + SFCs?
Old Dec 28, 2006 | 01:23 AM
02WS6M6's Avatar
Default STS + SFCs?
Has anyone installed a STS kit w/ diamond-type SFCs? I have SLPs and I don't want to give them up for a STS kit.
If so, can you post or email pics of how you did it?
Thanks.
Old Dec 29, 2006 | 08:53 PM
02WS6M6's Avatar
ttt - anyone?
Old Dec 29, 2006 | 09:13 PM
99Z28LS1's Avatar
i believe chromoly has some that were made for the STS cars, but they're $500+
Old Dec 29, 2006 | 10:38 PM
navymitch12's Avatar
trt sells some i think that work with the sts kit
Old Dec 30, 2006 | 02:51 AM
RooRnZ28's Avatar
i think you would have to redo the piping in order to make subframes fit... i had umi sfc's, and the sts charge pipe goes right in the driver's side sf's place
Old Dec 30, 2006 | 06:41 AM
ScreaminRedZ's Avatar
registered user
I was thinking about getting an STS kit until I found out that I'd have to remove my SFC's.
Old Dec 31, 2006 | 09:03 AM
great421's Avatar
Thanks.
I'm running into (no pun intended!) the same problem; I may just remove my DR side triangular SFC and go with a simpler, one piece, single chunk of square tube that only has two points where it bolts to the bird vs. the (very stiff) 3 point design, which is currently installed.
MLE
Old Dec 31, 2006 | 10:09 AM
Eatinstang4life's Avatar
I am building my own reqr mount I have spohn sfc's I just ran the pipe along side the sbc up tight against it that turned in along my header fits fine and I am using 2.5" pipe
Old Jan 1, 2007 | 08:28 PM
trans2000am's Avatar
sts kits charge pipe acts just like a sfc im in the process of removing my driver side one right now, little pain in the neck but hey i wanted this turbo kit so im not gonna let a sfc get in the way,specially when the charge pipe is a sfc. just my .2 cents
Old Jan 1, 2007 | 11:20 PM
the charge pipe bolts on to the the sub frames yes but I hope you don't think that you are actually connecting the frames together in a sturdy ridged connection as a real sfc does.
Old Jan 2, 2007 | 12:26 AM
ZL1Killa's Avatar
...i just took my sfc's off....no big deal to me
Old Jan 3, 2007 | 11:50 AM
yeah i know that but its better then not having any, Ill be keeping my passenger side on,its bolts up in the same location, maybe you are thinking about their old kits havent seen them but i know the new ones do.
Old Jan 3, 2007 | 03:29 PM
koolaid_kid's Avatar
I have seen one set for the STS. However, the company that made them decided to make them EXTREMELY expensive. Such a shame, greed, greed, greed.
Old Jan 3, 2007 | 06:27 PM
ZL1Killa's Avatar
but they are probably so expensive because they are unable to determine the market for them along with the market for the STS kits... as its a new thing and most people would normally want the turbo in the front of the car., but hey you figure all the people that have gone rear mount up here and that have wanted SFC that they would reduce the price
Old Jan 3, 2007 | 07:37 PM
deadmanTA's Avatar
Ask Billy at TRT, but I think I read something about STS was coming out with a kit that works with the sfc if you already had them welded in. I think was going to added into the options/upgrades that you can get when you order the kit.
Old Jan 4, 2007 | 03:53 PM
sts said the pipe connects right up where a sfc would go i got the kit the pipe is beefy looking.but you cant have the passenger sfc connected still.
Old Jan 4, 2007 | 06:30 PM
BeachZ's Avatar
I also was looking at an STS kit until I found out about the SFC issue. I would think that with that kind of power adder you would need more frame rigidity, not less.
Old Jan 4, 2007 | 06:44 PM
grifter757's Avatar
I just deal without it not to bad I would say.
Old Jan 4, 2007 | 08:29 PM
BeachZ's Avatar
Understood, but the extra torque created by a power adder can twist your unibody into a pretzel-like configuration, and it happens over time. Just my .02.
Old Jan 4, 2007 | 09:07 PM
yeah true, but if you keep the passenger side one on,plus their piping that they claim is as strong if not stronger then a sfc. ive got the kit that pipe seems pretty strong. ill try to post a pic soon if no one seen it yet.
