Gears and Procharger
Old Dec 29, 2006 | 05:04 PM
SKI's Avatar
SKI
Cool Gears and Procharger
I would like to know what gears are you guy's running.I have 7# progharger and m6 .I am running out of gear with 410's.I don't want to use 5th gear.thanks
Old Dec 29, 2006 | 05:14 PM
SSmokin 01's Avatar
3.73's
Here's a thread that will help you.
https://ls1tech.com/forums/forced-induction/605884-fi-cars-what-gear-ratio-you-running.html
Old Dec 29, 2006 | 07:46 PM
SKI's Avatar
SKI
Thank's for the site ,but alot of them are turbo's i am instreded in prochargers.
Old Dec 29, 2006 | 08:58 PM
My2kz28's Avatar
just go with a taller tire? I have 28" tall slicks and 4:10's and i go through at the top of 4th
Old Dec 29, 2006 | 09:23 PM
EPP's Avatar
EPP
Smile
Exactly. Go to a taller 28" tire, which I was using in this video. http://video.ls1tech.com/video/89b2f...a4011bec07.htm Bob
Old Dec 30, 2006 | 12:22 PM
SKI's Avatar
SKI
Is there any problems fitting that size tire ?
Old Dec 30, 2006 | 12:24 PM
2001CamaroGuy's Avatar
Why would you go to 28" tires if you are going to turn around and install higher gears to bring the RPM back up? Are you looking for more sidewall? Plus, bigger tires = more weight
Old Dec 30, 2006 | 01:05 PM
NA$TY-TA's Avatar
I would do Both...... go with a 3.73 and a 28" tall tire....
I did do both LOL back when i had a D1-SC kit..
You have more roll out with a 28" tire and sooner or later your going to want to go faster and the 2" the tires give you arent going to be enough.....
Kyle
Old Dec 30, 2006 | 06:42 PM
Whitez406's Avatar
What rpm are you topping out through the traps with 4.10's? I personally like motives 3.90's but i believe im gonna go 4.10s anyway. I have same combination as you and my rev limiter is set at 6600
Old Dec 30, 2006 | 10:01 PM
Slowhawk's Avatar
LS1Tech Sponsor
I like the 3.73's for a stock motor/procharger setup.Then we change the valve springs and move the rev limiter to 6500rpm. 4.11's I think only go to 115-117mph in the quarter with 26" tall tires at 6200rpm.
Old Dec 31, 2006 | 06:25 AM
EPP's Avatar
EPP
A 28" tall tire has more surface contact. Think of it this way with these two circles. oO
A 28" tall tire also shocks the surface much less, as the larger sidewall takes up a lot of the initial shock, meaning you won't be as apt to lose traction off the line. Bob
Old Dec 31, 2006 | 09:29 AM
Packy's Avatar
I have 3.73's and 27" inch tires and still have about 300-400 rpms left in fourth when I cross the traps. I have always wondered what 4.11's would do for my car... Sure wish I would have got them when I ordered my 12 bolt.
Old Dec 31, 2006 | 07:20 PM
Whitez406's Avatar
Im gonna be doing 4.10's and 26" tires.
