Delphi confirms Cobalt sensor #12580698 is 2bar.
Old 01-08-2007, 07:29 PM
Coal Mining Director
onfire's Avatar
Default Delphi confirms Cobalt sensor #12580698 is 2bar.
Hi Tom
Sorry this took so long but here is the data sheet that you requested. The part number that you had was a GM part number. Please use Delphi part number 09350899 to purchase this part.
Thanks
John P. Licavoli
Power And Signal Group
Customer Support Engineer
09350899 is a 0 to 200kPa BAP sensor used in the Cobalt SS.
Old 01-08-2007, 07:34 PM
frcefed98's Avatar
What did you think it was? And is it the right sensor for the job if running a 2 bar SD OS? I'm asking because this is the sensor I have in the car right now, I'd hate to be running the wrong one.
J
Old 01-08-2007, 08:01 PM
onfire's Avatar
J
I thought it was 2bar, but kept getting posts that it was a 2.5bar.
HPT even listed it on their site as 2.5bar.
It's great for a 2bar OS since it plugs in and is very accurate.
The confusion started since the Cobalt SS uses a 2.5BAR map combo sensor. It also uses a 2.0 bar BAP sensor.....which is the one that plugs into the LSX intake.
Old 01-08-2007, 08:03 PM
frcefed98's Avatar
COOL, glad I have the right one in the car, thanks for clearing that up.
J
Old 01-09-2007, 12:34 AM
LSs1Power's Avatar
There is a new 3 bar sensor with the same outside casing as the Cobalt sensor which makes it a bolt on and the low resolution of the old huge 3 bar sensor of 40Kpa. Do u know where can we get it from? Its listed under Delphi website with a part # under of 16249939, but there is no part for it in GM.
Thanks
Old 02-07-2007, 08:21 AM
blown3qtr's Avatar
Onfire,
Can you post the data sheet for the 2bar sensor #12580698?
Thanks
Old 02-07-2007, 09:01 AM
onfire's Avatar
http://www.powerandsignal.com/docs/P...s/09350899.pdf
Old 04-05-2007, 11:02 AM
FastKat's Avatar
That damn sensor better be made of gold.. I just ordered it and it costs $59!
Old 04-05-2007, 11:01 PM
s/c'd cav's Avatar
the cobalt's 2.0 lsj motor does have a 2.5bar sensor , its a TMAP sensor , it has the IAT sensor built into the map sensor , shown in this link
http://www.cardomain.com/ride/531077/10
the 2.0 LSJ motor also has 2 other MAP sensor , it has a MAP sensor in the inlet of the s/c , and never see's boost , then it has a MAP sensor being used as a baro sensor
which of the other 2 maps are the 2bar sensor ? im asking because ive got the 2.0 LSJ motor sitting in the garage , as a extra for the g/fs 2.2 eco s/c'd cavalier , so i should have 1 and since i dont need it for her cav , ill need it for the aps-tt going on my goat
Old 04-06-2007, 08:53 AM
onfire's Avatar
Post a pic here of the two map sensors showing the numbers on the back of the sensor.
Old 11-30-2009, 01:54 PM
ericwilloughby's Avatar
Thanks
What happened with this? I'm looking for >2 bar plug and play map sensor for the ls2.
Old 11-30-2009, 04:07 PM
bad6as's Avatar
do these sensors fit in the same spot as the stock map sensor?
Old 11-30-2009, 05:40 PM
onfire's Avatar
Yep, just installed one in a LPE TT Vette.....and threw the maf awayyyyy.
Old 11-30-2009, 06:24 PM
11SECSS's Avatar
Thats the same one I have for use with my maggie on SD.
Old 12-01-2009, 01:57 PM
You guys are talking about the 2 bar cobalt sensor right? What about the 3 bar sensor, does it fit?
When you through away the MAF, what do you do about the IAT sensor?
Old 12-01-2009, 02:38 PM
onfire's Avatar
2bar. IAT stays in the system as a stand alone sensor....easy with fbods...with some vettes you have to take the 2 wires from the maf sensor and wire in an IAT sensor.
Old 12-01-2009, 05:05 PM
bad6as's Avatar
how manny psi do they read to?
Old 12-01-2009, 07:04 PM
onfire's Avatar
Top out at 200kpa. So roughly 14.7psi of boost since you have to substract 1bar.
Old 12-02-2009, 04:34 AM
Jontall's Avatar
Thanks
The 16249939 part number has to be wrong. The only one it can be is from the Solstice Stage II kit: 55206797 Sensor T-MAP (Bosch Part # 0 281 002 845, supposed to be used on Alfa Romeo 159 1.9 JTD
http://www.gminsidenews.com/forums/f...ble-now-72622/
Also the Volkswagen Golf 2.0L Turbo
Old 12-02-2009, 04:41 AM
Jontall's Avatar
GM Parts Direct is listing the 55206797 sensor.
Quick Reply: Delphi confirms Cobalt sensor #12580698 is 2bar.
