PAGING Jose and other!!!!
Old Jan 9, 2007 | 06:02 PM
ninetres's Avatar
Default PAGING Jose and other!!!!
Quick easy question:
I am buying a short block ASAP. I am going to run my T76gts. I tried my best with the compressor map but I am not so familliar with how to accuratly analyze my motors needs.
Would a stock bore 364 be more efficient than a 370? Thanks. I would like to maximize my T76gts without choking it at all.
Old Jan 9, 2007 | 06:19 PM
Frost's Avatar
The GTS has no map
But it seemed everyone's consensus was stock-inch or as close as possible would be best, especially if you wanted to really max it out.
Old Jan 9, 2007 | 06:21 PM
DrTurbo's Avatar
LS1TECH Sponsor
That is correct........stock cubes work great.
Old Jan 9, 2007 | 07:03 PM
ninetres's Avatar
Stock cubes as in 364? I want to go iron.
Old Jan 9, 2007 | 07:13 PM
DrTurbo's Avatar
LS1TECH Sponsor
Well err stockish.....
Old Jan 9, 2007 | 08:54 PM
ninetres's Avatar
lol
**** it. I'm gonna go with a 364, since it sounds like a 370 would be too big.
Old Jan 9, 2007 | 09:44 PM
Smearin's Avatar
370 wouldnt be too big..
thats a good setup...
Old Jan 9, 2007 | 09:50 PM
SSilverSSurfer's Avatar
370 is the biggest i would do on a 76, plus the extra cubes will allow for a nice sized turbo later on down the road if desired, for instance an S88 on a 370 like Kyle
Old Jan 9, 2007 | 10:39 PM
Snyper's Avatar
Originally Posted by ninetres
lol
you think 6ci will make that much of a difference?
Old Jan 10, 2007 | 02:12 AM
Mr_president's Avatar
DRturbo.....how much of a difference would a 370 hurt the t76 choking wise?
Old Jan 10, 2007 | 03:44 AM
Snyper's Avatar
how much over a 364?
Old Jan 10, 2007 | 08:01 AM
V6 Bird's Avatar
lol
Its not really the cubic inch in this equation as it is how much the cylinder heads will flow for you in your setup. I think thats right.
If you've got a badass set of heads and a cam to match them for your application then you can run the turbo you want with smaller cubes and still be better off. Now if the heads and cam are fairly stock it would take more to make out that turbo at 364 CI then it would with a sweet heads cam setup at less cubic inches. You have to look at the whole picture with that motor to choose the turbo setup. Airflow i believe plays more of a role then does CI..
Old Jan 10, 2007 | 08:24 AM
Frost's Avatar
I'm saying backpressure through that t4 flanged 76 is gonna choke that thing out up high much quicker than on a 34X" engine... Remember Kyle's large-frame 76 (GT42 I think) on those same cubes and what his results were...
Old Jan 10, 2007 | 08:44 AM
RealQuick's Avatar
Whats the goal for the car? ****, engineermike has ~700rwhp with his 383ci LTx log manifold kit with a T76GTS THRU AN AUTO TRANNY. If this isnt going to be an all out race setup, then you'll be fine 383ci or under.
Old Jan 10, 2007 | 12:21 PM
V6 Bird's Avatar
I also would like to believe he has a very nice set of heads on that 370" motor too We'll let him chime in.
Old Jan 10, 2007 | 04:27 PM
ABeasst's Avatar
better flowing heads wont help it would actually hurt. The more air that comes in the more that has to go back out and thats where the backpressure is made. Enough exhaust cant flow throught the exhaust housing and exhaust so backpressure builds up.
Old Jan 10, 2007 | 04:31 PM
NA$TY-TA's Avatar
Yes they did flow rather nice..
I just know what we saw with my combo.... and what happened when we switched to the S88 with less boost....
Kyle
Old Jan 10, 2007 | 05:02 PM
Smearin's Avatar
I dont think you can compare the s88 to a 76.. those things flow very well .. i think the only thing comparable is that they are the same size...
Old Jan 10, 2007 | 06:11 PM
V6 Bird's Avatar
I can agree and disagree with this.
The engine is one big Air pump...The more efficient it is with moving air the more it will create issues on the back side.
Old Jan 10, 2007 | 06:32 PM
NA$TY-TA's Avatar
Did you really even read this thread????? It was comparing when i had my GT42-76mm turbo and how choked i was with it with a 370ci motor.....
Turbo to small..........
