How about everyone give updates on their setups?
To be burning gas and tire in 2007!!
Check out my page:
http://www.buyrcars.com/jag.htm
have to finish welding everything tacked together and do the fit and finish.
I need to get a flexplate this week and I'll have everything to drop in the th400/RMVB/brake. The 12-bolt will go in at the same time. I need to install my Wolfe 6pt bar (bad) and need to get the cutout under the car. I need to buy big-n-lils. I want the Madman manual rack.
This is my first FI setup, so it should be fun
simillar to the tti street. 850miles on it well it runs good 460whp thsnks to don.. 6.0 heads walbro and inj. stage 2 4l60 36-3800 tci everything eles stock prety much installed 96lb injectors and currently working on a 3bar SD tune.
waiting for my tranny to be done as i am also putting in a th400 with a brake.
o ya, and my BOWED ******* hi-flo header flanges are being milled/straightened
ughhhhh i hate this game. so much work, so little time
Added a MSD BAP and have to run a wire to it to give it juice and ground it.
May and probably will set up regulator as boost referenced.
Then I'm gonna retune it again and then go click some new passes on my worn BFG tires. May tune it in speed density.
Want to do a slightly smaller pulley to bring in boost faster. Also want to add nitrous.
Down the pike is maybe a 6 pt bolt in cage since tracks are getting stricter and a thicker rear street sway bar..
Need to get some big n littles on this car.
Hope my 10 bolt holds up!
Got car back from LS1SpeedInc
They did the 2bar SD conversion with swap to PP Stage 3 LS6 68cc chambered heads...
They also freshened up the TH400 and the converter..........
Feels really good even @ 9PSI.....but now I have a glitch in my fuel pressure (drops in PSI every once in a while on startup, for a milisecond, and then goes back to normal just cruising around town, hasn't ever happened to me on a WOT blast)....sooooo I'm gonna have to drop the tank, pull them out and inspect the wiring harness, hoses/lines...and crap...ohhh what fun
Now I just have to buy a laptop to tune with
Getting really close though!
Been concentrating on the chassis first (cage, wheelie bars, suspension, etc)
Putting SFI 25.5 cage in right now (7.50 ET cert)
Motor plates and midplate are installed
Griffin radiator is installed vertically
Parts for custom-built 1 3/4 Stainless headers are ordered
Belt-driven fuel system is here (Along with a custom ATI damper to drive it)
I plan to trying to push the turbo to its limits (1300-1400 fwhp)
