Would like some motor advice and input please for an incon setup.
My goals are simple as I don't expect to, nor wish to make that big four digit horsepower number as most do now, but instead I would like to make around 590 rwhp to maybe 600 rwhp if all were to work out perfect on pump gas. But I will be happy with 5xx rwhp as that is quite a bit for the street if you ask me.
My plan is to put together my stock motor with just a set of pistons, cam, and maybe heads but would like to keep my stock heads and run just valve springs to save some money for the turbo kit. I already have ready to use, a LS2 timing chain and Texas Speed stock length pushrods. Oil pump is still undecided as to which to get but might go with the newer Melling high volume oil pump that has been worked over by thunder or someone else. The cam is possible a 04 ZO6 one or maybe something else that is recommended for my goals. Pistons rings I would like to have total seal stainless steal rings for the heat and to limit blow by.
I want to run my stock connecting rods with arp 2000 rod bolts, new gm main bolts, arp head bolts, and arp header bolts because the incon manifolds are so heavy and big.
Now to make this horsepower the flywheel horsepower will be about 600 or so and I want to know if you guys think this setup will work for the mean time until more funding can become possible.
I know if I had the money I would do it all out right but because I still have allot of things to acquire for the turbo kit that will cost allot, I can't afford to do the motor the best. However after most likely spending $2000 or so to get my turbos rebuilt I would like to avoid a little peace of ring landing destroying one of the new CHRA's or causing housing damage so that is why I want to do the pistons instead of putting the kit on my completely stock short block.
I believe KP, and cablebandit have both ran stock rods up to a good amount of horsepower so if they could add some info on their old setups that would be great. This car will only see the drag strip once in a blue moon so street is where this thing is going to live most of the time.
I will be using speed density tuning either by using a Parish style mega squirt or by HP tuners done by Jim at Speed Inc.
Fuel system will be decided as money comes but most likely use 97 corvette fuel rails with regulator or maybe a breathless replacement regulator. However if I have the funds I may use Speed Inc or Nasty rails and regulator if I have the money. The fuel pump will be a racetronix single pump but would like the dual if money allows and will be using the included wiring harness no mater which kit I get. Injectors will be motron 60 pound as I want to be able to have plenty of fuel as that is what will keep this beast alive.
My questions are:
1) Do you believe this setup will reach my goals and last for a while?
2) What brand of pistons to use that will fit the stock rods for pin size and lower my compression to a 9 to 1 or even 8.9 to 1 with the stock heads and GM MLS gaskets?
3) What do you think of my choice of piston rings and do you have a better suggestion?
4) Is the ZO6 cam the best for me or if not what do you recommend?
5) Any other helpful info or suggestions do you have for me, please?
Sorry for such a long post but I appreciate your time reading it and I hope by breaking it up, that it made it easier for you to read.
You used ross pistons with your old setup and the stock ls1 cam too then, cool, that helps to know. Thanks allot cablebandit for you help and if there is anything else that you happen to mention that might help me I would appreciate it. Did you end up keeping your incon kit or did it end up selling? How do you feel about the high volume oil pump for the turbos.
Also what bearings do most here like to use for the rods, mains, and cam as I will have the block cleaned and new bearings put in just for good measure and wanted to know if clevite is what most use or just stock gm.
I've twisted and turned a TO4E and it's not going to fit well. Plus the T25 exhaust housing isn't going to handle 60lb/min either. Plus fitment issues with the internal gates, linkage, mounts. It's not a reasonable upgrade. 50lb/min CHRA's and stock cubes will give you room to grow into 800rwhp.
I see, thanks for the info and help onfire, I am sorry to hear of all the trouble with them TO4E housings. As for room to grow, 800rwhp through a T56 is plenty to me for my F-body even in the future if I were to decide and pursue that level of power. I still have to make new wastegate brackets for mine as the previous owner lost them and the actuators so I am going to have a hell of a time getting that all worked out to fit but I know I can figure it out. Thanks for chiming in.
The Clevite bearings are what I was thinking about using but I thought about using them on both the mains and rods as good bearing are cheap insurance for a motor to last. But Federal mogul mains are also real good and a little cheaper to I believe so I guess I will just have to see what comes unless I am missing something and should only run Federal mogul bearings in the mains, please let me know. I will probably use Federal mogul bearings for the cam even though my motor only has 13080 miles on it so the bearings should be fine but like I said cheap insurance and I even have the tool to put them in as I have done cam bearings before for other motors that I have put together but of course non that have made as much power as what I am hoping for.
Thanks Cablebandit for some more awesome help and input. I guess the next thing to do would be asking some sponsors who would have and know of which piston manufacture would have a set that will drop my compression to 8.9 or 9 to 1 with stock 62cc chamber heads or am I going to have to find some 317 castings and clean them up.
