MAF Help
btw Frost, I liked your bumper so much that I decided to do a similar cut-out pattern for my camaro...looks bad-*** on the car!
Obviously the picture is before I polished her up and such...but you get the concept of it.
And with a 2bar, you can only run ~15psi tops.
edit: your best bet with those hp goals is to go hpt/efi - sd in 3BAR...trust me, youll want more power down the road so you might as well do it once and go 3bar.
Nice, and thanks !
2-bar supports up to 14.7psi. You can go higher, but fueling is blind past that point like it is past 8-9psi with the MAF, so you must fuel for highest boost and accept being rich on the climb. The 3-bar goes higher but you lose some table resolution.
