Kenne Bell supercharger?
When i buy my C6 vette the only mod it will get is a KB and a fuel system. That bitch be nice and quiet with the exception of blower whine. Just how i want my next car to be. My TA is noisy.
The Kenne Bell S/C is considerably taller than a Maggie. PERIOD. Or at least while it is bolted up to the motor.
That being the case, it doesnt take a rocket scientist to figure out that if a Maggie requires modification, then the KB will require even more..
motor in relation to the cowl. Corvettes differ there of course.
...lots of cocky comments in this thread...still waiting for pics.
And FWIW theres a reason there is no pictures, and its NOT because no one wants to show them. Its because there arent any..
You are close on your measurements (within a 1/2 inch) SO I would go back to someone with a maggie and reverify the height. I have a feeling your measurements for the maggie are wrong. Also, measure the I/C'd version AND NON I/C'd version.
http://www.magnusonproducts.com/imag...-CAMARO-TR.jpg
[QUOTE=AMERICAN_HP]Well, I will do what I can to get you the pics you need. I am one of the guys who worked with KB in R&D'ing the LS1 kit. I have worked very closely with KB for quite some time now. If ANYONE knows the dimentions of this system its gonna be me. The last photo helps you get a general idea as to how tall this thing sits.
American_HP, can you run a tape measure from the valley cover to the highest point on the back of the unit, this should put to rest how much hacking will need to be done.
I would take the KB over the APS if it would fit, but the easier route here isn't going to be the KB. If I knew I wouldn't have to hack into the windshield wiper or higher, I would still consider it.
Love the car!
For the little time and sacrifice to put it in and get it going....id DO IT!
There is nothing like the hit of the low end torque from those bad boys!!!!
I could measure it, but since its been at Ricks shop, I 100% re-did everything in the engine bay. I'm currently running the prototype 2.8H blower. So the ONLY measurements would NOT be an exact. They would be within a 1/4" of the 2.6. The 2.8 is right around 3/4" longer than the 2.6. So since I dont have the 2.6 in front of me, I'd hate to quote you an EXACT #. As far as the height, that will be easy.
How much boost are you running now? Any chance of squeezing any more power out of that 2.8l?
.If I could get some close dimensions on it, sure would make it real simple to see if it would work, or at least how much hacking would need to be done.
Your right, I believe your KB was the first one on a LSX car, I was lucky enough to see it when it first came in. In hind sight, I should have measured it then but didn't phathom putting it in an f-body
. I could take this blower to 25psi if I wanted to. The operating RPM of the blower was nowhere near its max speed.
We did do a 18psi run but we shut it down at 4200 rpms. I didnt feel like picking up the pieces of my motor on the ground. Needless to say, my numbers were ALOT higher than what everyone knows mine to be..
The motors being freshened up at LME now. It WILL be built for 20+psi.
