Kenne Bell supercharger?
However, what is the advantage of getting 800 hp from a twin screw over over forms of FI like a turbo, a procharger, or twins?
If they would design the SC to work with the Fbody Accessory drive they wouldn't have to design a specific kit, which I know they never would because of the cutting and since the aftermarket kind of shuns us Fbody crowd.
Heres my "Decent" top end power..
I'm just playin with you...
http://videos.streetfire.net/search/...eb00d58f63.htm
What about that pulley combo I asked you about? We have the exact same combo eg. engine size, heads and blower in the Hummer? Currently, we're seeing 9PSI with the 3.5 pulley. My guess is the 3.0 pulley would be about 11-12PSI in Cory's (LS2 Portworks) Hummer. Eventually will want 15-16 PSI after adding METH...My guess is your using a 2 7/8 upper pulley? These Blowers sure do work well..........
Kick *** power by the way....
We are running the 2.8 H series (silverado kit)...I was thinking a 3 inch pulley(not made yet for the truck) would give about 11-12PSI with a 7.625 Truck lower pulley...Looks like a 8 inch lower pulley is in Cory's future for now until there done...
It will be interesting to see what hp you get out of your new combo...20 psi (assuming the intake tract from t-body to blower will not be the restriction) should give you 900RWHP....
Man, my post sure is screwed up on this thread...Shows up like a day later and now I can't delete the extra ones...
For everyone else's information the 2.8L is the same height as the 2.6L just longer...
http://www.ls2portworks.com/Trucks.html
Here's the original post over on the truck section about installing it...
http://www.performancetrucks.net/for...8&page=1&pp=10
