Kenne Bell supercharger?
Old Apr 4, 2007 | 12:15 PM
  #41
Juiced's Avatar
any idea what you expect to make at 25psi?
Old Apr 4, 2007 | 02:45 PM
  #42
GrnDragon's Avatar
What all are they doing to the engine to make it hold 20psi?
Are they resleeving the block and adding billet mains?
You were running a stock LS2 block, sleeves, and mains correct?
Sorry to ask so many questions I am just wondering what "should" be done to a block to make sure it will hold that kind of HP and TQ, or if it would be worth buying a Warhawk block for a build like this.
Thanks for all the information, I still believe the 2.8L can fit, but my ideas of what can be done are WAY off from others. Just look at my cardomain page in my signature and you will see what I mean...
Old Apr 4, 2007 | 03:29 PM
  #43
Juiced's Avatar
My block is being built for the same thing, fully studded, huge head studs, o-ringed block and heads, copper gaskets, and good internals but mine is iorn so it's bit more stout than an ls2, billet mains and a girdle might be a good idea.
Old Apr 4, 2007 | 04:22 PM
  #44
crazy02ss's Avatar
Someone needs to make a KB or a Whipple fit on ls1 f-bodys!!!!!!!
Old Apr 4, 2007 | 05:04 PM
  #45
Juiced's Avatar
I might try and make it fit but i'm not opposed to putting the sawzall and cuttoff wheel to work.
Old Apr 4, 2007 | 07:04 PM
  #46
crazy02ss's Avatar
I would not either i like the best of both worlds a twin screws makes
Old Apr 4, 2007 | 07:49 PM
  #47
DanZ28's Avatar
Me either, to an extent!
Old Apr 4, 2007 | 10:09 PM
  #48
chief_jz's Avatar
Someone try this! I'd try it on a donor car, one that may have had rear damage, to cut and make templates for the firewall, before i hacked up my own ride.
Old Apr 5, 2007 | 01:23 AM
  #49
Justin00SS's Avatar
I saw we convert the camaro to mid engine.
Plenty of room back there for everything.
Old Apr 5, 2007 | 01:56 AM
  #50
chuntington101's Avatar
....or youcould just buy one of these!!! loads of room back there!!!
http://www.ultimasportscars.co.uk/
thanks Chris.
Old Apr 5, 2007 | 01:57 AM
  #51
Justin00SS's Avatar
thanks Chris.
.. OOOOOOOOOOOOOOOOOR
You could get a Pantera!
kb'd LS1/6/2 in that car and omg............:nut:
Old Apr 5, 2007 | 07:25 AM
  #52
Ed @ Late Model Speed's Avatar
The I/C Maggie is just shy of 9.5" from the lowest point on the manifold, to the hihgest point on the supercharger. Magnuson does have bigger blowers on the works, and I am trying to get my hands on one to do some fitment work.
Believe me, this roots setup is great with a 112, and with a bigger blower, it will be even better!
Ed
Old Apr 5, 2007 | 09:04 AM
  #53
crazy02ss's Avatar
Something needs to happen for the f-bodys
Old Apr 5, 2007 | 09:54 AM
  #54
mattraypharbor's Avatar
+1^^^
Old Apr 5, 2007 | 09:55 AM
  #55
prices need to be resonaible.
Old Apr 5, 2007 | 02:08 PM
  #56
Juiced's Avatar
My car is a drag car, the cowl area is already getting removed for weight and aesthetics
Old Apr 5, 2007 | 04:51 PM
  #57
Jeff@TotalPerformanceEng's Avatar
Ed, My blower will be off the car for about 3 more weeks. If you want, I will be more than happy to ship it out to you so you can try and mock something up.
If what your saying is true, it might work. I would just think you would have to turn it around and run a jack shaft like the maggie. This wouldnt be too awefully difficult, it would just take a little creativity. I am just blown away that the KB requires such a larger hood, but its essentially the same height.
Let me know and I'll box it up for you.
Ed
Old Apr 5, 2007 | 05:17 PM
  #58
I'm not sleeving or O-ringing anything. Its really not all that necessary for my application. I will not be running that high of boost all the time.
I'm running wiseco forged pistons, callies crank, manley rods, AFR 225 heads, ALL ARP studs, larger ARP L19 head studs, clevite bearings, and a billet main stud girdle. Obviously there are a few other things, but these are about the most important.
Old Apr 5, 2007 | 07:11 PM
  #59
Houdini's Avatar
ED - Take AMERICAN HP up on his offer, we would all love to see a KB made to fit.
Old Apr 5, 2007 | 07:44 PM
  #60
Rabada's Avatar
+1 for Ed to take up the offer. So what is it like driving a car with insane low end torque? I am considering something like this for my car next year.
