Cheapest F/I kit for LS1?
I'm looking to get a kit for myself, for around 4k or under.
Any supercharger kits out there? I'm not so much a fan of STS rear mounted turbokits.
Thanks,
Patrick
http://www.procharger.com/GM/gm_auto.shtml
soem guys ahve gotten away pretty cheap doing junkyard turbo setups...but thats not a kit and it will take some skill and some time.
D1SC or P1SC: around $1k ( less if used )
FMIC: $4-500 if done yourself
Bracket, Pullies, and SDCE tensioner setup: Around $700
injectors and a fuel pump: $5-600
Tuning: $500
Roughly $3k, depending on what you buy new and/or used. This will get you about 450-480rwhp. Remember it's only the begining though. Add a clutch if your a M6, and a rear end if you plan on putting traction down. The list goes on and on from this point.
Its a bitch to line back up later if you remove it though for cams or what not so make sure you get it all done prior to installing the pin. Its not hard to do nor expensive, but if you go with a S/C its definitly something you have to do. The last one i did i lost the pin so I cut a 1/4" cobalt drill bit and used the soild end as the pin lol. Most venders have kits for these, and they are not too bad on price. Check with venders that sell alot of ATI's, Vortechs, or Magnachargers. They will have them.
i would agree i picked up a full d1sc with 8 rib setup for 3k, that included a polished plenum and fueling...
just watch the Sale section and wait for a good deal to come along
BOSS APPROVED!
