OFI build taking shape..no 56k
i think its called a vacuum distribution manifold...1/4" for the brake line and 1/8 for the vaccum/boost lines
I got those firberglass wire protectors on them.how hard is it to change the plugs though, can you get them off without removing the headers?
Yes thats another concern I had ... I had tought of maybe using these headers
Im getting lazy... Now on the fiberglass boots... i run them...... now everyonce and a while i burn a plug wire when i street drive the car alot.....
Thats why i keep an extra one in the car LOL
Havent burnt one in quite a while..... MSD's are the worst..... ill never buy them again.... Taylors here...
Keep us updated.
Kyle
A/c will be fine...no worries there...I can heat tape it if needed.
ABS block...I dont have one but the OFI dyno thread shows the abs block being in the same general area as stock. That same guy has been driving his a week now and the only issue he said he had was air in the cooling system. Once he got that out, no prob.
Ill try to get a pic of the boot protectors today.
Care to elaborate on what items baked with the incons
Looks great Jerry, I bet you are as eager as me to have the car running
Condenser is behind the radiator....between the radiator and engine. Just idling today in the garage (where my a/c works least efficiently) the temp in my garage was 78ish and the air out of the a/c vents was 42ish degrees so it should be fine there.
Nasty, I am not too fond of MSD wires myself. I think I will try something different if these dont work out. I saw some late model ls2 wires that had right angle spark plug boots...that might work well for this setup
Plug access.....dunno yet.....it looks like its gonna be about a 30 minute job. Maybe less since it looks like you can get at least 4 from the bottom easily.
filter breather i think i got from speedinc
Never had the problem with the cutouts open.
Mind you I was doing better than 160mph, thats a LOT of wind that SHOULD have aired things out underneath.....apparently not. This just gives you an idea of how hot things get down there.
