OFI build taking shape..no 56k
Like we talked about before... ive had better luck with taylor wires then the MSD's....
Let us know man..... How long till ya can really lean on her??? Track?? Dyno??
Kyle
I think part of the problem with the crossover may be the fact that I already had the headers LONG before I got the 2nd shipment which included the x-over. So when Joel mocked everything up he was using a different set of headers. Maybe over the months the jigs for the headers have changed slightly or whatever I don't know but it definitely isn't even close to fitting.
The wastegate looks like it will fit with a little tweaking and aligning of stuff. The DP which is actually the part I was most concerned about seems to be ok as far as routing past the engine. Just the fact that it doesn't fit snug enough to the turbo to actually get the v-band on is not cool. Also, the turbo is so close to the balancer I think trying to fit a turbo blanket is out of the question. I guess it needs to be that close to allow the condenser to fit.
Cablebandit, did your DP clamp right onto your turbo? Our turbine housing outlets should be the same...
Nasty, i drove the car 50 miles today...plug wires are fine so far......the plastic zip tie CLOSE to the header is still there and not melted as well.
Onfire....got into boost some today...a/f was 10.6-12.1 even though the dashboard says commanded a/f was as low as 8.6....dunno whats up with that. I thought i blew the motor taking off one time...smoke was everywhere behind me and trailing for a bit...then i smelled lots of rubber in the car
Maybe its the cold pavement but this bitch has major traction probs....even at 7psi. I am gonna go out tomorrow and try to dial in the afr in boost some more. Today just spent with 2 second spurts just to see how things acted...what got hot etc...feeling it out. I just did my 100 mile oil change and tomorrow I will get a bunch more miles on it. I just gotta figure out how to dial in a/f under boost. The Best V8 Stories One Small Block at Time
I guess I should just send the hot parts back and have him redo the stuff but I would like to have the car running in the near future. I already fixed the radiator necks that were too long, had the inside of the DP cone welded where the 3.5 inch pipe was sticking out inside and looked nasty. Plus I already waited 4 months for the stuff to begin with. Supposed to drive it to OC, md for cruise in week the 3rd week in may and would just rather get the mess fixed myself and be on my way instead of sitting around waiting for stuff again.
https://ls1tech.com/forums/showpost....89&postcount=3
Joel offered to remake a DP for me but have not heard back, since then I've found a local guy who builds turbo's for mustangs and is a awesome TIG welder, he remade the whole DP for me and fixed my crossover pipe too, as well as a few other issues. Its costing me another $1k to fix this stuff though
it was that or send it back to Joel and wait another 15 weeks or something crazy like that The stuff will line up before I tighten it or I won't tighten it plain and simple. If you are going to put that much stress on everything you may as well not bother with a support for the turbo!
I'm calling Joel now to see if I can at least get another pass header that fits better so that I can at least put the a/c comp back on in the future and not be so damn close to the evap case in the back. Well see how that goes...
i think its called a vacuum distribution manifold...1/4" for the brake line and 1/8 for the vaccum/boost lines
.You setup looks awesome BTW!
Joe
Sounds like that should work out well.
Might have my A/C back on in time for the beach after all!!!
