OFI build taking shape..no 56k
Old Apr 17, 2007 | 12:56 AM
  #81
MonkeyBoneSS's Avatar
Any updates on the install cable?
Any issues with the system yet?
Old Apr 17, 2007 | 12:53 PM
  #82
obZidian's Avatar
anything new cable?
My kit just arrived today. I guess we'll test fit first than have it sent to powdercoating.
laterZ!
Old Apr 17, 2007 | 01:03 PM
  #83
cablebandit's Avatar
Alrighty. Here is the current situation. The a/c condenser radiator config does not work. The hot radiator air blowing across the condenser eventually drives the a/c pressure high enuff to get the compressor to short cycle..aka..no a/c. Joel is aware of this, already ordered a condenser that we hope will cure this problem. I am sure Joel will contact everyone once a good solution is available. It will be fixed so dont worry about that.
Other than that, I have had probs with #5 spark plug wire. It touches the header and then cooks. As long as it doesnt touch, its fine. I use MSD wires and have a few extra. There is 1/4" of boot that can be trimmed off where it touches and that SHOULD give us PLENTY of air gap to alleviate that problem. No probs with the rest of my wires.
Kit is making awesome power...dunno how much yet but i will try to hit the track sunday. I do know that in 3rd gear at around 55mph....go wot and as it reaches around 80-85mph, you lose all traction!! I am getting a cutout installed friday and another bracket to support the turbo. I will let everyone know about the bracket....should work better than Joels...according to Joel himself. I like it that he is open to new ideas.
I have had no probs with leaks or heat with the power steering or anything else...just the one plug wire which I hope will be solved in a few minutes.
Old Apr 17, 2007 | 01:10 PM
  #84
obZidian's Avatar
the condenser would be that catch-can looking over on the passenger side, right?
sounds good though, it helps to have a builder that is willing to add to his kit or product without take to-much offense.
getr' don!!
also, im using the stock radiator which will be shifted over enough to clear the hairdryer! What tires you running cable?
Old Apr 17, 2007 | 01:55 PM
  #85
smokinHawk's Avatar
that would be the dryer (also called accumulator)
Old Apr 17, 2007 | 02:04 PM
  #86
SSblack98's Avatar
The condenser would be the large flat radiator-resembling item in front of the stock radiator...
Looks like I may not have a/c for the beach after all.
I will actually just be happy to drive the car to the beach...or around the block for that matter...
Old Apr 17, 2007 | 03:23 PM
  #87
Cable where did you get your spark plug boots?
Old Apr 17, 2007 | 03:27 PM
  #88
Superado's Avatar
11 Second Truck Club
O'Reilly has the DEI brand...
Old Apr 17, 2007 | 04:08 PM
  #89
obZidian's Avatar
oh, thanks hawk. Interesting, im not understandin why or how is there now an increase in temp. emitted from the radiator and to the condensor. Isn't the condensor infront of the radiator?
cable, thats a aftermarket rad. right? Also, are you running a front mount a2a of a2w? Could the condensor be flat mounted, much like the dual intercoolers in the procharger kit, so it can get a direct charge of cooled air and away from the rad.? Cable, you had a incon before this, was your a/c working prior? What do you think might be the cause with this new kit to enduce more heat on the condensor?
  #90
Tiago's Avatar
Originally Posted by smokinHawk
those vband clamps are pretty close, just put them on and crank them down, they will fit. looks good to me.
I would not recommend this unless you want warped/cracked headers and leaks.
Old Apr 17, 2007 | 04:16 PM
  #91
Darren P's Avatar
how about running hot in bumper to bumper traffic or setting at a stoplight
how does it handle that
Old Apr 17, 2007 | 04:17 PM
  #92
Superado's Avatar
obZidian...
the OFI kit comes w/ a different radiator and moves the a/c condenser to the backside of it...push fans on the front of the radiator push hot air through the condenser...eventually kicking it off...as he explained several posts back...
Jerry is running a A2A FMIC...and yes he had a/c w/ the the Incon set-up...
hope this helps...
Jerry...didn't mean to speak for you...
Old Apr 17, 2007 | 04:26 PM
  #93
you are a faster typer al
Condenser used to be in FRONT of the radiator...OFI put it behind it and now it catches all the hot air from the radiator. Joel is working on a solution
I got the DEI fiberglass boot covers at Advanced Auto or Oreilly auto...summit has em too
a/c worked fine with incon
Old Apr 17, 2007 | 04:39 PM
  #94
NA$TY-TA's Avatar
Jerry......
The taylor wires work much better since the head of the wire that goes on the plug is alot smaller.... i had the same problem with MSD'd and the protective boots on there as well.....
switched to the Taylor wires and now its only once in a while.... but that hasnt been for months now.... i still carry a spare just in case LOL
Looking good so far man.....
can wait till ya hit the track.
Kyle
Old Apr 17, 2007 | 04:53 PM
  #95
ok here is the #5 wire as it sat
it could move as close as this ...suprisingly it wasnt burn at all
here is where i cut the boot
you can see its 1/4"
i got the boot tight against the wire close to where it comes close to the header...used a steel tie from DEI at oreillys
now you can see the clearance is much better...sharpie for reference
final clearance with the wire ziptied to the coil pack. Its ghetto but will work
Old Apr 17, 2007 | 04:57 PM
  #96
Superado's Avatar
dat's yo middle name cracka'!
Old Apr 17, 2007 | 05:19 PM
  #97
e'r'body in da club gettin' tipsay!!
I dont recognize the car after i washed it!! I forgot it was white not beige.
Gonna clean my prostars tomorrow so it looks good on the AAA rollback
Old Apr 17, 2007 | 08:40 PM
  #98
SSilverSSurfer's Avatar
you plan on breaking some stuff this weekend?
Old Apr 17, 2007 | 10:14 PM
  #99
Superado's Avatar
shhhhhhhh.....no one say another word.....
Old Apr 17, 2007 | 11:25 PM
  #100
obZidian's Avatar
"another word"
Well, seems as if i don't know what i paid for.. DOH!! I hate being away from my car...!!
ok, is there away then to mount it flat like a procharger intercooler? That might help..
