OFI build taking shape..no 56k
Old Apr 18, 2007 | 06:06 AM
  #101
Superado's Avatar
11 Second Truck Club
Originally Posted by Superado
shhhhhhhh.....no one say another word.....
about Jerry breaking sumpin' or riding on a AAA rollback...
from looking @ Jerry's, I don't see where you could mount one horizontal...all you need is a smaller one with appropriate connections...to be able to mount it back in the front...which from what I understand, Joel is looking in to...I found a few that are for Subaru's that we thought may work...
Old Apr 18, 2007 | 08:13 AM
  #102
obZidian's Avatar
lol... i was just being an punk!!
right, well, is there enough room with the pusher fans to get it mounted infront of the rad.? I ask because i got the same kit, and need a solution as well...
Old Apr 18, 2007 | 08:16 AM
  #103
Superado's Avatar
it seems that there is...as long as one is found with the appropriate dimensions...
Old Apr 18, 2007 | 08:18 AM
  #104
onfire's Avatar
Coal Mining Director
Good luck Jerry. I hope it tunes into the 9's on the second pass....
Old Apr 18, 2007 | 08:32 AM
  #105
obZidian's Avatar
excellent!! a subi one huh? I may have one laying around... do you know which year you were looking at?
Old Apr 18, 2007 | 02:05 PM
  #106
cablebandit's Avatar
95-97 subi i think.
Onfire, I hope it does too.....my wife said 10.20....I think her lack of hope is due to my small pecker...I am sure it was a letdown as well
I think it will run just a TICK faster than Mightymouse did 9.90-10.0...thats the goal anyway. David and I have pretty much the same setup...basically same turbos..raceweight and all with same tranny. I figure I should 60' better and that is where I should be able to improve on his time. Once he gets the t-brake tune/kaunch figured out, he is gonna LOVE the auto at the track!!!
Old Apr 18, 2007 | 03:19 PM
  #107
Project Dc2's Avatar
any pictures of how you cleared all the air conditioning stuff and the clearance around the turbo setup ? thanks !
Old Apr 18, 2007 | 03:37 PM
  #108
no clearancing needed for the a/c stuff at all...just gotta get the right condenser from Joel....it worked at idle when coolant was cold or if you reversed the fans to DRAW air across the condenser. he will get it straightened out.
Turbo area is VERY tight....i only found one filter to fit...a small K&N filter (i think a ru-5163)....I got one thats just screen for the track also . If you get a t-4 turbo like a t-76, you have much more room. I was concerned about the tiny area/filter at first but even it will flow all the air i can use on the street. If that doesnt answer your question, post up and ill get whatever pics you need
Old Apr 18, 2007 | 03:39 PM
  #109
it answers my question.. However i am tryin to develop my own kit for my car and pics would help GREATLY. Especially since this setup maintains a/c and all factory creature comforts which is A+ in my book.
Old Apr 18, 2007 | 05:11 PM
  #110
obZidian's Avatar
well, if you are interested, joel does sell or i believe he sells his hot pipes... you could be those and fabe the rest.
Old Apr 18, 2007 | 05:31 PM
  #111
thats what i did...bought the hot parts and radiator...fabbed the cold side which was easy as ****!!!
Old Apr 18, 2007 | 06:14 PM
  #112
eesh .. hot parts for 2295$ ill make my own =) not to say its expensive if i were a consumer but then again, i do build turbo setups =) Just for a motor that has half the cylinders. Plus, i want to make mine out of some thickwalled stainless. Only other company i seen make LS1 turbo manifolds out of the same material is Phamspeed
Old Apr 18, 2007 | 06:20 PM
  #113
ohioboost.com i believe. Joel makes a good kit but if you have the means to make your own, you could do even better!! Every car/setup is a little different and you should not try to copy someone elses work but just make your own..APS keeps a/c as well as Tunas kit and so does TTI street kit...forgot about PTK as well
Old Apr 18, 2007 | 06:24 PM
  #114
indeed !! However, its always wise to see what someones done before to avoid any future headaches that could've been avoided with a little research and browsing.
Old Apr 18, 2007 | 07:52 PM
  #115
reverse type headers....crossover in front of the motor...nothing really special...just gotta know how to weld/fabricate...i cant do either
I am anxious to see spool time difference and boost level with closed exhaust vs cutout...i will post the data this weekend
Old Apr 19, 2007 | 07:44 AM
  #116
obZidian's Avatar
projectdc2: show-off!!
well, if you think about it, all you have to do is imagine that you are building the kit for two rice-rockets. anyways, that turbo is bigger than that motor. B-series honda or an H?
Old Apr 19, 2007 | 09:16 AM
  #117
i build for B , H, D, and F series ( integra, prelude, civic and accords) i just ordered a GT4088R turbo, little smaller than most conventional turbos found on here, but ill be on a stock motor and im only lookin to make 550-600 at most with a decent spool time so i can still play in the twisties.
Old Apr 19, 2007 | 01:29 PM
  #118
I am too skurred of the twisties...if something goes wrong...here comes a tree...thats my fear anyway
Old Apr 19, 2007 | 06:42 PM
  #119
did you retain ac ? i see the air con drier but wheres the condensor ? also is that a custom radiator you have ? specs? price? im guessing its a howe or griffen etcc. also did you remove your ABS or was the vehicle not equiped with one ?
Old Apr 19, 2007 | 07:20 PM
  #120
i removed abs a long time ago trying to get more braking to build boost on the footbrake.
condenser is right behind the core support but out now as Joel is working on something better. Radiator is custom that you get from Joel...i think he has someone make it...**** fits like a GLOVE!!
