more boost with restricted exhaust?
Old Apr 16, 2007 | 01:34 PM
cablebandit's Avatar
Default more boost with restricted exhaust?
Before I had the 3.5" downpipe on my OFI kit actually mated to my 3" magnaflow catback, it seemed most boost it would make is 13.8 psi (dunno what spring is in the gate) on just spring pressure. Now that the pipe is all mated, my boost on spring goes to 17.8....4psi difference. Does the backpressure hold the tial 44mm wg closed more and allow the boost to go up? It felt more powerful or at least the same power at 13.8 vs 17.8 psi...i attribute that to the lowered exhaust flow i now have. I am getting a cutout friday but just wondered in the mean time if this is a common occurence.
Oh, torco does work.....i got some kr after 16psi but torco totally eliminated it....this was today...same tank of gas...IAT everything...got knock...added torco...drove for 5 minutes to let it mix and then no more knock.
Old Apr 16, 2007 | 01:37 PM
DrTurbo's Avatar
LS1TECH Sponsor
Yes its common.....
Old Apr 16, 2007 | 01:58 PM
thanks....are th t-6 blankets in stock right now so i could order it?
Old Apr 16, 2007 | 03:10 PM
DrTurbo's Avatar
LS1TECH Sponsor
Yes they are. Also for the mid-frame turbos such as yours, they are being labeled T5 blankets. Weird, but only way to seperate all these frame sizes.
The links are now up....
http://www.forcedinductions.com/product7.htm
Old Apr 17, 2007 | 10:55 AM
engineermike's Avatar
I had exactly the opposite experience. With a 10 psi spring in the wastegate, I was seeing 11 psi boost with the full exhaust. When I removed the "cat-back", boost went up to 16-17 psi.
Mike
Old Apr 17, 2007 | 11:54 AM
onfire's Avatar
Coal Mining Director
On the TB/2step at 2500rpm my boost jumps from 4.8psi to 6.2psi when I open my cutout.
Haven't checked wot yet.
Old Apr 17, 2007 | 12:07 PM
SSblack98's Avatar
Can you actually fit a turbo blanket with how close the turbo is to the crank pulley?
I was looking into one but didn't think it would fit...
Old Apr 17, 2007 | 01:17 PM
i dont think it will fit either? As soon as DRTurbo said it was in stock, i ran outside to look and it looks too close. Prolly just get the housing coated and let it rip
Tom, let us know what the boost reaction is at wot with/without cutout.
I am getting one friday and will do the same....hope to hit the track sunday...
Old Apr 17, 2007 | 02:21 PM
MIGHTYMOUSE's Avatar
if the w/g is routed into the dp you can see an increase in boost w/ restriction or no boost change at all.. what is more typical is that when the w/g is vented outside (dumped) you can see a loss of boost w/ restrictive cat back.
Old Apr 17, 2007 | 04:59 PM
David, mine is routed into the dp....and i see an increase in boost. After i get the cutout, I bet it will haul *** at 18psi....as you already know with your setup
onfire's Avatar
Just tried it out. Two 2.75 pipes to a sincle 3.50 pipe to a 3.50 cutout to a 3.00 pipe that runs to a Borla with one side completely open.
Cutout closed = 11.5psi
Cutout open = 12.0 psi
based on EB2 memory
Higher boost may make a bigger difference.
Old Apr 17, 2007 | 08:39 PM
TURBO383WS6's Avatar
i hate to hijack your thread, but i'm about to run into the same delima i think. i've got a 3.5" DP and 3.5" all the way out the back w/ a spintech muffler. i've decided to put a magnaflow 3.5" flow through muffler in it's place running straight out the back. do you guys think it'll increase boost by switching to a non-chambered exhaust or decrease it?
Old Apr 17, 2007 | 09:02 PM
Be careful. I severely blew both head gasket, to the point of hydrolock, doing what you're about to do.
I had my car set up running about 20 psi using a 3.5" Aerochamber muffler. I made no other changes except replacing the muffler with a 3.5" Magnaflow with the same external dimensions. I have no idea where the boost went, but it was high enough to do said damage. That's when I found that the minimum boost was now 17 psi instead of 11 on just the WG spring.
Mike
Old Apr 17, 2007 | 09:27 PM
Mike
i can't begin to thank you enough! i think i'll wait till i've got a little more time to tune on it. got a race this weekend and just thought the muffler might give me the edge i needed. not worth it. thanks again!
Old Apr 17, 2007 | 09:29 PM
Turbo383Ws6, our combo's are very similar. I have the T76GTS on a 388 LTx. What mph are you running at the track? Dyno numbers? I've been thinking about going with a 3.5" downpipe instead of my 3", but can't decide if it's worth it.
Mike
Old Apr 18, 2007 | 10:45 PM
onfire's Avatar
Played with it some more today. Turbos spool much quicker with the cutout open....much better on the brake...only gains a little booost up top.
Old Apr 19, 2007 | 08:22 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Seems like if you have restrictive exhaust, the boost at the turbo will be high but not after it.
I'm running a 4" DP and a 4" exhaust with a bullet dumped at the rear axle, no real restriction there.
Old Apr 19, 2007 | 02:11 PM
my wg is referenced from the turbo....i followed the eboost instructions and did it the way they said..my boost gauge is referenced from the intake. Ill have a cutout tomorrow and can say definitively what MINE does
Old Apr 19, 2007 | 02:37 PM
With an electronic boost controller, backpressure should not affect the boost level since it's a feedback control system.
Old Apr 19, 2007 | 02:58 PM
i am just running off the spring...got the eboost2 on the lowest setting....
