OFI results
Old Apr 24, 2007 | 12:14 PM
  #41
cablebandit's Avatar
wow!! All these numbers and i is confuzed!!
I want a gasket seat plug....next step colder than tr6...whatever that is. "tr-8" idles too rough so i want to shoot for in between
PSJ...my combo
408 9.3 c/r
TSP PRC ported Darts...225s...refurbed "smokers"
238/238 116lsa 590/590
rhoads lifters
eagle crank-rods-wiseco pistons
girdle...forgot that guys company..
OFI hotparts with vsracing 33x12x4 i/c
tial knockoff bov/wg
s488 from Mikes Turbo .63 comp housing 1.32 exhaust housing
3.5" dp to 3" magnaflow catback...3" cutout just under drivers seat
transformance 4l80 with rossler t-brake
fuddle 2400 stall (works awesome!)
8.8 rear with 3.55 gears
96# injectors with versafueler
275/60/15 MT DRs at 16psi cold
it should be around 3850-3900 raceweight now but i will find out for sure next time at silver dollar raceway. Wanna know anything else?
Old Apr 24, 2007 | 12:19 PM
  #42
thanks 2k1bird for the vid
http://s91.photobucket.com/albums/k3...t=100_0321.flv
Old Apr 24, 2007 | 12:24 PM
  #43
Superado's Avatar
11 Second Truck Club
gasket seats in heat range of 7:
BP7EFS (3526) same projection as the TR6's
BKR7E (6097) designated as projected
R5671A-7 (4091) "non-projected" like the -8's you ran before (the one on the left)
Old Apr 24, 2007 | 01:01 PM
  #44
Superado's Avatar
Originally Posted by cablebandit
that damn white drum is in the way!!!
where are Dave's still shots? I want to see daylight under those front tires
Old Apr 24, 2007 | 01:19 PM
  #45
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Nice vid, your car sounds great.
Old Apr 24, 2007 | 01:34 PM
  #46
thanks PSJ cutout is not as bad as some
Al it didnt pull the tires....I had shocks on 10 to keep the front stiff....i can loosen em up to pull the tires but it unloads the rear when they come back down.....lower i keep the front end...longer i keep traction. Pulled other head..its fine gasket got hot but new ones are ont he way!!
Old Apr 24, 2007 | 01:41 PM
  #47
NA$TY-TA's Avatar
Damn Jerry.... all the Plug Talk has me wondering..... I have been running TR6's for ever in my motor..... on the street and on C16....
No problems.......
I wonder if i should go with a colder Plug...
Old Apr 24, 2007 | 01:53 PM
  #48
Superado's Avatar
great news on the other side! gonna run the same GMPP gaskets?
I've always been told that at that level of power, picking up the tires is the easy job...it's keeping them down that is harder to do and more important in lowering the ET...
Old Apr 24, 2007 | 02:56 PM
  #49
Nasty...everyone is different as far as what they like. For max effort on mine and your setups, i think a tr6 is too hot. I like the wot performance of the "tr8" but not the idle. Since we both drive ours a lot, I think the "tr7" is a good compromise. Thats 2 steps colder than stock. I think KP still uses the tr6 heat range....not sure but i bet he will chime in. He doesnt like to run his car in the heat and i do which is why i want to drop down a heat range...hotter IATs. This is all just my opinion...btw
Old Apr 24, 2007 | 03:00 PM
  #50
Superado's Avatar
those autolites that kp is running are -8
equivalent to the ngk 7173's
Old Apr 24, 2007 | 03:07 PM
  #51
kp's Avatar
kp
Actually I run -8 NGK racing plugs in the AFR heads, forget the number, with the dart heads I used the AR3911s or 3922s.
You wont foul out -8s unless you are driving around at 10:1 a/f.
Old Apr 24, 2007 | 03:31 PM
  #52
ahh...the -8 ngk didnt foul...just idled rough. Also when it was cold and tranny went into lockup, it would misfire. tr6 fixed that so i am gonna try in between i think...i got the 3923 from one of your posts and thats what i have now but i THINK its the same heat range as tr6...if its closer to a -7, ill keep them...time to go plug reading on the net
Old Apr 24, 2007 | 03:47 PM
  #53
AL...wtf...looks like the autolite 3923 i have now crosses to a BPR8ES ngk...if that is a -8 heatrange...ill just keep using these. Is that a -8 heat range? Its all so confusing. If its a -8...wonder why they idle so much better than the ngk -8 i had unless its a projected tip vs no issue
Old Apr 24, 2007 | 03:48 PM
  #54
Superado's Avatar
3923 is a -6
http://www.ngk.com/results_cross.asp...CrossWarning=1
you are confroosed...
Old Apr 24, 2007 | 04:02 PM
  #55
Superado's Avatar
here's another chart showing the same...
http://www.dragstuff.com/techarticle...reference.html
Old Apr 24, 2007 | 04:08 PM
  #56
Superado's Avatar
and another extensive chart...
scroll down to line 444...
http://www.adirondackkarting.com/mas...ence_chart.xls
Old Apr 24, 2007 | 04:10 PM
  #57
Superado's Avatar
Jerry, your brain is going to split like that radiator hose Sunday...
info overload
Old Apr 24, 2007 | 04:18 PM
  #58
NA$TY-TA's Avatar
Ok got ya...
so what is the PT # that advanced or autozone woul need for the TR7's or 8's.... ie the # for TR6]s is 4177's....
Ill pick up a set and see.
Thanks
Kyle
Old Apr 24, 2007 | 04:34 PM
  #59
Superado's Avatar
to recap...
these are tapered seat:
TR6..........4177
BP7EFS....3526
R5724-8...7317
R5724-9...7891
these are the "non-projected", gasket seat:
R5671A-7 thru -9 would be
4091,4554,5238
these are the projected tip, gasket seat:
BKR7E........6097
R5672A-8...7173
R5672A-9...7405
  #60
LS1Tech Co-Founder
I have run 3911's, and TR8's, all got the job done. I am running different plugs with the AllPro heads, I forget which ones.
