ST-series T4 turbo
Old Jun 16, 2007 | 02:44 PM
  #101
longrange4u's Avatar
Originally Posted by jaydubb
Will the ST80 choke a 383?
It will flow as much as my PT88 so I would say no...
Old Jun 16, 2007 | 03:04 PM
  #102
Dbluegoat's Avatar
Originally Posted by JZ 97 SS 1500
That is correct guys. All the ST units have all been fully CNC'ed and are ready for shipping. Unfortunately the turbine housings from BWA were the wrong flange T6, and not T4 as ordered. So we are expecting the shipment of housings this week and ALOT of ST units will be leaving. We also have a new turbine wheel coming out as an option for these units in the next 3 weeks. Under testing it lowered backpressure on a 408 Windsor by about 18lbs at 18lbs of boost. It was worth quite a few ponies
I hope mine is one of them..... I ordered on the 6th
would you guys stop making new this or thats...damn it we cant even get them on the car before something bigger and better is coming...
Old Jun 17, 2007 | 07:31 PM
  #103
Mekkadon's Avatar
Are you running an on-center or Tang V housing???
I'm asuming tangenial V. It is a T4 turbine housing.
Old Jun 20, 2007 | 04:43 PM
  #104
Dbluegoat's Avatar
hey whats the status on our stuff......
Old Jun 21, 2007 | 10:38 AM
  #105
DrTurbo's Avatar
LS1TECH Sponsor
Those that wanted the pictures for the ST-series with a PT88 here they are below...... Comp cover is just a touch larger, but the turbine housing is smaller and the turbo is shorter as well.
Attached Thumbnails ST-series T4 turbo-img_3301.jpg   ST-series T4 turbo-img_3302.jpg   ST-series T4 turbo-img_3303.jpg
Old Jun 21, 2007 | 12:12 PM
  #106
stevieturbo's Avatar
Whats this S465 titanium turbo like ?
A 65mm unit that flows 90lb
Surely its got to be impressive ?
Old Jun 21, 2007 | 12:13 PM
  #107
PHIL H's Avatar
Arent you guys coming out with an ST88 also? If so what will it be rated at? 1400+ hp? What are the NMRA drag radial guys running since they are limited to 82, 85, or 88 mm turbos? I am sure they are T6 housings arent they? Just trying to understand the advantage of the T6 housings over the T4 in the 1500 hp and under world..
Old Jun 21, 2007 | 02:11 PM
  #108
Dbluegoat's Avatar
Old Jun 21, 2007 | 02:56 PM
  #109
cablebandit's Avatar
i thought yours was already running or are you switching from a 76?
Old Jun 21, 2007 | 03:13 PM
  #110
Dbluegoat's Avatar
switching
  #111
DrTurbo's Avatar
LS1TECH Sponsor
The Ti wheel is heavier wheel and not really all that great for quick spooling setups. Ti is used in high heat, high pressure setups, such as a single turbo pulling truck or race truck. Diesels with singles and lots of fuel can make some BIG boost and LOTS of heat. We build a unit now with the same comp wheel though made in HIP'ed AL which is lighter and will flow the same amount of insane air.
Old Jun 21, 2007 | 03:16 PM
  #112
DrTurbo's Avatar
LS1TECH Sponsor
All CHRA's and comp covers have been done for weeks. The correct turbine housings arrived today (finally) and ALOT of units begin to leave tomm. More then likely yours is on the list I'm sure. You guys are going to start kicking some real *** soon.
Old Jun 21, 2007 | 03:27 PM
  #113
GTO30272's Avatar
DrTurbo, PM sent.
Old Jun 21, 2007 | 04:30 PM
  #114
So given my past queries....re a circa 900bhp capable turbo for a smallish motor....
This unit, with such a small compressor, is surely looking like a hot contender ? It has the top end, and with such a small compressor, surely it will spool fast ?
BB option ?
Old Jun 21, 2007 | 05:52 PM
  #115
DrTurbo's Avatar
LS1TECH Sponsor
BB option ?
No BB option yet, but its coming. Also yes we can make these suckers spool pretty nicely and make big power.
Old Jun 22, 2007 | 09:39 PM
  #116
ninetres's Avatar
Did my turbo go out today? I called a couple times to get a tracking number.....but no answer.
ST80 and T5 blanket headed for Fresno California....my initials are SJC. Tracking number???? Please!!!!
Old Jun 22, 2007 | 09:50 PM
  #117
NA$TY-TA's Avatar
Hope yours is headed out to ya.....
I called yesterday and talked to JZ... looks like all were waiting for is the covers for mine
Kyle
Old Jun 22, 2007 | 10:44 PM
  #118
ninetres's Avatar
Kyle
except your turbo es muy grande senior
Old Jun 23, 2007 | 10:15 AM
  #119
NA$TY-TA's Avatar
si un pequito
Old Jun 23, 2007 | 06:18 PM
  #120
ninetres's Avatar
BUMP
I have a SERIOUS race on July 8th.....and it would be titty-licious to have my new turbo to romp on people with!!!
