Finally dyno'd with the D1
Must still be slipping. When I get on it, I hit 10# right away, then very slowly I will hit 11# and thats spinning it to 6500.
Also IAT's go from 85* to 135* and this was on a very cool night.
Will pick up another belt and try the 3.4
Guess I'll leave the 3.2 in and focus somewhere else.
As said, the belt has to be banjo tight, I was running the 12 Rib with my D1 and could make up to 19+ lbs of boost. My Lt4 383 made 648 RWHP @ 12lbs on pump gas, at one time I had trouble making boost and kept trying smaller pullies but the problem was the orange flexable intake tube that comes with the kit, when it got warm it was actually collapsing so I fabricated a steel intake tube. No problems after that...
I'll look into a new BPV, but I don't want to spend money where it isn't needed. I thought getting the D1 would solve it.
Everything is starting to point to the inlet hat.
KP uses the stock hat and so do i... we put a extra filter on the by pass hole to accomodate a little more air:shrug:
With the SDCE, I don't think the belt is the problem But I will change it out with a new just to make sure.
The P1 also hit 10# at 6400
Cam Motion cam. 222/226 .595 115
Don't recall the IAT temp on the dyno. But on a cool night a blast in 2nd gear, the temps went from 80* to 160*
i'd say check your stock ATI bypass as it makes the most sense.... I'll let you know what happens with mine.... if its not the bypass on mine or yours i will be looking at the cam for the blame.....
i talked to a reputable procharger sponsor and i asked him where he thought a 224/236 cam would peak at and he nailed my dyno sheet right on the head... 5800rpms.... he said he would like to see my motor have atleast a 234/238 114lsa... maybe the intake duration on a procharged car can make for a longer power band..
maybe its just a coincidence maybe not... but hell i could see i was gaining boost on my dyno sheet but i lost power... so when this winter comes and my theory is still lurking... i'll check into a set of after market casting heads and a BIG cam...
CR is 9:1
