corvette twin turbo
ohh and do you plan to stepup the boost.. isnt 4 a little low?
the engine is 100% stock,dont want to turn it up and break the engine.Cant do anything with it the way it is,has stock wheels and tires,spins through 4th gear
well ill keep updating as i get info
EDIT: upon further investigation the turbos are made with garret internals
Last i heard garret is owned by honeywell, and air research has not had thier names on turbos since the late 80's maybe even early 90's. but then again i do not know much of lots of the new stuff out there.
and watch out as i know of more than a few turbos that were sold as factory fresh garret rebuilds to fail within 500 miles. best bet is just have them rebuilt and rebalanced NOW as most ebay turbos last a fair amount if you use good parts as the housings are of better quality now.
im really debating on ordering the fbody one (looks exactly the same as the PTK) and just getting a good turbo to be safe and still be out the door with lots of extra cash in hand
if this is against the sponsor rules (i didnt list a price or seller) then ill delete this post or a mod will do it for me...
EDIT: if i do get the fbody kit im going to have the turbo tore down and fully inspected and rebuilt (if its worth it) if not ill be gettin a new one
it was a link to another ls1 forum about this kit.. guess im not allowed to do that..
The knock off I'm not so sure.
one of the holes on the flange was off by about 1/16 to an 1/8 of an inch, just enough to where the bolt wouldnt start, so he had to open it up just a tad...
ill post more pics as the install moves along (no instructions, so everything is being played by ear)
Chris.
tomorrow we'll prolly relocate the alternator, relocate the powersteering resivior, and the overflow tank.. and start removing the stock crap on the drivers side
here you see the relocation of the radiator
and the bracket supplied
just another random shot
tapping the egr
looks nice sofar
also you will want to relocate the coil packs. if you mount them low they dont have to run anywhere as near to the headers as if you dont.
thanks Chris.
