Turbonetics GT-K 500 and 550 questions??
We build them here with some different options. Alll depends on what you want as far as comp wheel, and turbine wheel match up. The 500 and 550 are just standard 60 and 61mm wheels.
What's the max you can get one to flow that would be T3/T4?
Vince I imagine your talking about the TTI kit correct?? Doesn't the TTI kit use TO4B covers (2.75" inlet) though, or can you fit the E-cover (3"inlet)??? If so Jose is working on a set of turbos for the T3/T4 guys that will blow the cover's off the current units available on the market.
Dont the new GT-K series run the new compressor wheels ?
As for Earl H., I am watching your Viper setup as well. I know quite a few people in my area thinking of running your very kit, but they want more power and upgraded turbos would help them as well..
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
In ball bearing or oil journal ?
Originally Posted by W8N2SQZ
Are these new turbos that Jose is working on come with internal waste gates?
How much air do they flow?
Thanks,
Glenn
Thanks,
Glenn
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
FWIW, a GT67 flows 71lbs/min
They will be built in both chassis, using hopefully ETT wheels if everything works out. The problem is alot of CNC machine work is going to go into all of this, so it may take a little bit before I get all the final details.
I want a fast spooling, T3 flanged BB unit with the black Turbonetics GT-K cover, that will flow enough for a real 600bhp on a 2.2 motor..
Then also a T4 flanged BB unit ( price dependant, oil journal may suffice if there really isnt any performance/durability advantage ) 70mm ETT turbo for a 2.35 motor... for circa 900+bhp
Cool...
All the units can be built that you have just mentioned.
BTW, the ETT 70 made 900.XX at the wheels on a 2JZ so far. Also the new ETT 80mm with larger turbine made over 1200WHP on a Pro car Scion. These bastards are making power.......also new turbine wheels are coming as well for some turbos. The future is bright. Also we have a new GT42-70R DBB that is priced ALOT more competively with a new CHRA. I think you guys will like it.
Originally Posted by frcefed98
TO THE TOP UNDELETED FOR VINCE.
Vince go to turbonetics owners forum website the link is in my sig, under the tech forum post up this same question. Robert should be able to answer it there.
J![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
J
Not a problem.....
and if Josh see's this CHECK YOUR PM's...I know you are lurking in the FI forum![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I believe they can be made to run internal gates as well. The top wheel in the E-cover will flow 81lbs/min ![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
FWIW, a GT67 flows 71lbs/min![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
