STS Low Oil Press Warning
im getting the low oil press warning tone from my STS kit when im on high boost - 9psi , when im running 5psi the tone does not come on . anyone run into this before, or have any idea where to start looking for the problem.. the tone is not constant is beeps in and out. appreciate any help
x2 on what trtturbo stated!
There is also a hi/low switch on the STS harness near the buzzer, you may want to ensure that it is on hi. I have tried it on both settings when under 6-9 psi and with it on low the buzzer went off.
did as advised i turned the allen screw about 1/2-3/4 turn and problem solved on my boost run coming home from work
by the way can you explain what that does for the pump by turning the allen screw???
It doesnt do anything to the pump at all. The pressure switch is there only for the buzzer. If too much pressure builds up in the return line, the buzzer goes off. You just adjusted the pressure it takes to turn the buzzer on.
