IAT sensor in air intake for meth injection
This is for a meth injection app.
Thanks to anyone who can help.
Yes, this is what I am attempting to do. When in the intake manifold and not spraying, is the IAT reading correct? In other words, doe it read a little higher temp than it would have if it were in the stock position??
Not enough to hurt anything.
After the air starts moving, it's accurate. If you put an aluminum intake on and sat running for 20 minutes...probably not.
My aits before and after the relocation were the same around town, etc.
that is great! did you use HPTuners to verify IATS before and after relocation?
Mine is setup just past the methanol nozzle in the elbow (as shown in the pic). The actual IAT sensor sits back a bit so it doesn't get direct methanol mist on it, but it still reads the temperature accuratly. Even if the sensor eventually goes, its only a $10 part you can pick up at AutoZone. I'm guessing honestly it will take years of spraying the methanol before it actually corrods enough to do any damage.
