PVC Catch can system.... Final conclusive answer
Old Jul 18, 2008 | 11:22 AM
  #181
PhillyLS1's Avatar
Some AWESOME info here. This helped alot.
Old Aug 14, 2008 | 02:27 AM
  #182
one fast zo6's Avatar
dose a catch can really help.
Old Aug 14, 2008 | 07:49 AM
  #183
spaz1's Avatar
I think I need to do this too.
Old May 26, 2009 | 09:46 PM
  #184
KWIKKAR's Avatar
Ok just read everything and still not clear on what to do..
I have a APS kit with about 1000 HP.. Right now I have the Driverside rear VC port going to the inlet side of the turbo pipe, Pass-side rear VC port also to the Turbo inlet pipe, Filter on oil cap, front pass-side VC capped, And running LS6 valley to the non vented Catch can and back to the intake on the 92FAST. Is this right?? My rear main already went out after 300 miles so I'm thinking its wrong. Let me know
Old Sep 9, 2009 | 04:58 PM
  #185
67Firebird455's Avatar
Still not definitive. Will TTT to try and revive it. >=)
Old Sep 9, 2009 | 07:45 PM
  #186
vipvegas's Avatar
heres how Im going to run mine, seems to be the ticket from what I concur
Old Sep 9, 2009 | 08:33 PM
  #187
koji777's Avatar
I originally started this thread....... in summary, what would be the most cost effective and efficient way... without a pump.... to achieve an adequate FI(Turbo) system..... could someone PM me so I don't have a rehash on all the opinions stated in here. I just don't wanna blow my engine/seals out when I let it all hang out.
Old Sep 10, 2009 | 12:36 PM
  #188
On a "driver", wouldn't the inlet be sufficient? You don't spend THAT much time idling, you'll almost always be under load spooling, maybe not boosting, but enough to suck the bs out of the crankcase.
 Michael S. Palmer
Old Sep 23, 2009 | 12:46 PM
  #189
SVC707's Avatar
I dont have an inlet tube for my turbo. so where would i pull vacuum from? filter is mounted right to the turbo
Old Sep 23, 2009 | 04:16 PM
  #190
Rick_Vor's Avatar
Do you have room to add 1 1/2-2" spacer between the turbo and the filter? Then you could just tap you breather line into the spacer.
On my setup, I going to have to add a silcone 90 to extend the passenger side air filter out to add a hose from my catch can. I'm running two 3/4" rubber lines from both valve covers to a catch can on the fender with a small kn filter. It seems to work fine (30k miles at 10lbs) but it does smell when I pull up to a stoplight after a "spirited" run. What ever vapor does get sucked into the turbo, I imagine it will be "homoginized" to say the least.
Rick
Old Sep 23, 2009 | 04:38 PM
  #191
MIGHTYMOUSE's Avatar
mount in the black rubber cap on the filter, or in the neck of it.. anywhere on it.
Old Sep 23, 2009 | 08:31 PM
  #192
SKINNY69's Avatar
I think VIPVegas's diagram is the best setup I've seen. Maintains a constant vacuum on the crankcase and doesn't allow for any unmetered air to enter the engine. That setup could easily be done for $100 and it makes to old school breather filter method look asinine. It would work the same as the stock pvc system with the exception that it draws vacuum while in boost. Best of both worlds IMO.
Old Sep 23, 2009 | 08:54 PM
  #193
vipvegas's Avatar
here is the check valve I used this is assembled with earl super stock barbed ended it has a 1/3psi cracking pressure but can withstand 2800psi opposite and stainless. Makes them look nice and still a little on the wallet..
Ill post pics of my catch can in morning
Old Sep 23, 2009 | 09:15 PM
  #194
vipvegas's Avatar
This catch can is baffled so it actually traps the oil. Two ports go to valve covers. Last port goes to Ls6 valley cover. Or plugged if not. Other side -10an ran back and T'd off to a check valve then to stock pcv portunder tb in intake. After tee check valve to turbo inlet about 8-10 inches from turbo inlet in piping
Old Sep 24, 2009 | 12:06 AM
  #195
LS1Silverado05's Avatar
Nice looking units! Where did you get them? PM sent...
Old Sep 24, 2009 | 08:29 AM
  #196
vipvegas's Avatar
pm replied..
Old Sep 24, 2009 | 08:46 AM
  #197
mightyquickz28's Avatar
This is the routing I ended up with on my LT1. (Although I came up with it independent of this thread ) It just seems to be..
  • Effective
  • Cost contained
  • Simple
The underside of the oil cap is completely clean every time I look. Keeps the moisture pulled out of the motor perfectly.
Old Sep 24, 2009 | 11:40 PM
  #198
BLASTER's Avatar
where'd you get the check valves?
Old Oct 26, 2009 | 12:39 AM
  #199
unclebens's Avatar
I have a 2002 ls1 camaro, what is the pcv wire that goes from the passenger head around the steam tube up to the pcv valve?
Old Oct 26, 2009 | 11:19 AM
  #200
Aster's Avatar
Could be a grounding strap or just there to keep it in place. I removed it when I redid my PCV system.
I ran it like so, but then I'm speed density so not much concern about unmetered air. Capping the throttle body and placing a small breather next to the catch can routed to the front passanger valve cover.
Attached Thumbnails PVC Catch can system.... Final conclusive answer-single-catch-can-pcv.jpg
