Help with MBC, cant add more boost
http://www.jegs.com/webapp/wcs/store...0002_315228_-1
Also there are 9psi springs in the gates
First we turned it up 6 clicks, and the boost went up a little, next 6 more clicks, nothing, then 10 more clicks, nothing.
Here is how we have it setup
Manifold Pressure ---> Boost T ---> T --( two lines )--> Waste Gates Low Side
AFRs were in the 11.4 area timing 20deg
The port in the center of the removeable cover should be vented to air.
The other port takes the pressure reference.
Tial's website shows the line coming off the top of the gate goes into the MBC, then the outlet of the controller goes into a T where it joins up with the line for he side of the gate. The T also has a reference line to anywhere on the pressure side. Check this out and click on wastegate install diagram:
http://www.tialsport.com/techincal.htm
Once again be EXTREMELY careful if you decide to test it in this manner, and I take no responsibility if you overboost and blow stuff up
Hydrostream is on the money with the exhaust back-pressure unseating the valve.
The one you have now acts a lot differently because it doesn't allow any pressure to pass until you get to the threshhold you have it set to. This means if you have enough exhaust back-pressure, you will unseat your wastegate valve and be unable to make any more boost.
thanks for the tips
I'm pretty sure at this point I have a big exhaust leak in one of my gaskets some of the bolts are loose on the driver side manifold I noticed after I thought about exhaust leaks.
Also got the new exhaust gaskets so I think I'll put them on too and see what it does.
It also seems like its spooling a lot slower than it did last year, but I could just be getting used to things too. Kind of like how my R1 felt insanely fast when I first got it but now its just normal.
