Need lower compression
Old May 13, 2003 | 11:51 PM
Black01M6SS's Avatar
Default Need lower compression
I've saved up enough to get my supercharger/cam/clutch installed, but I'm worred about my motor and rear end.
Could I use some 6.0L heads to lower the compression? How much would a set cost? I've researched this but I'm still unsure on how well they will work on a stock 346. Does anything need to be done to them?
I will be installing a Vortech 9# kit with Aftercooler and a thunder racing supercharger cam with new valve springs.
What would go first, the rear end or the motor? Car gets run pretty hard. Its a 2001 with 56000 miles.
Old May 14, 2003 | 03:57 AM
gogogadgetcar's Avatar
Default Re: Need lower compression
if you run good fuel your motor will last for a while
Old May 14, 2003 | 06:08 AM
smokinHawk's Avatar
6.0's will loser the CR to about 9.8:1.
You can lower them a little further by using a thicker gasket.
This is a cheap way to lower your CR
when i got my 6.0's i did a mild port job and a 3 angle valve job.
Old May 14, 2003 | 07:37 AM
BIGBOS's Avatar
I think speed Inc has a deal going on now w/TEA..
You can probably get 6.0L heads w/whatever CC you want for cheap...
I have 73cc chambers in my heads, and that gives me 9.5:1 compression on a stock 346c.i. motor
Old May 14, 2003 | 09:43 AM
Crunch's Avatar
Go with TEA. They have the best prices and some of the best flow numbers around. I didn't go with the low compression heads, but even still, the 5.7L heads woke up my car to the tune of 536RWHP with the Vortech S/C and 8PSI. I'm sure you'll do even better with the 6.0L heads.
Old May 14, 2003 | 02:32 PM
The only 6.0L heads I saw on speed inc were 2200$. I'm just looking for something to get me by untill I can afford new pistons and rods. I figured I could find some used 6.0L heads for pretty cheep, install new valve springs and not have to worry about blowing my motor up untill I get enough money to rebuild it. Am I missing something? Why are the 6.0L heads so high. All I want is bigger combustion chambers...
Old May 18, 2003 | 11:22 PM
TTT
Old May 19, 2003 | 04:59 AM
cy's Avatar
cy
A guy around here is running 9psi on a stock LS1...no problems. You should be fine.
If you really want to, just buy some used 6.0L heads, i don't know if they'll flow as well as the 5.7L heads (or is that just the 5.3L's?) if they are unported. You should be able to just unbolt the 5.7 heads and bolt up the 6.0 heads.
I don't think the money and time are worth it, your stock CR should be ok with that. If you are THAT worried about it, i think the cheaper/easier solution would be to get 5 or 6lbs pulleys until you get your pistons and rods....just a thought.
