Why does my blower belt keep coming off?
Old May 16, 2003 | 03:19 PM
1slowCamaro's Avatar
Default Why does my blower belt keep coming off?
I dont think this is possible but can the belt being too tight cause it to come off? I know it couldnt have been too loose. The first time it came off I figured since it was a new belt it came off after it stretched a little and I didnt tighten it up again. So I put it back on and cranked her down. Only made it into about 3 or 4psi and it came off this time. The first time I was at high boost for probably 10 seconds before it came off. So since it came off quicker when it was tighter the problem cant be from being too loose. Just hoping the crank pulley isnt on improperly cuz thats a biznitch to get off as you all know.
You guys know how the blower pulleys look different on each side? On one side the area around the bolt hole is raised up more than the other side. Wondering if I put it on backwards. The side that was more raised is facing the blower. Any input would be appreciated. Thanks
Old May 16, 2003 | 04:19 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: Why does my blower belt keep coming off?
Was there a torque spec for the ATI pulley?
Old May 16, 2003 | 04:51 PM
They dont like you to change them yourself so I they dont give a TQ rating in the instructions. How does 50 ft. lbs. sound?
Old May 16, 2003 | 07:52 PM
Black LS1 T/A's Avatar
Moderator
The size stamp faces the compressor.
Mine is moved all the way down until it stops.
Old May 16, 2003 | 08:39 PM
1dirtyZ's Avatar
make sure the pullies line up ,
the blower pully also has a small spacer ring that you must use.
Old May 17, 2003 | 07:19 AM
Yesterday at about 6pm I was checkin to see if the pullies lined up and they looked like they lined up fine. Then I started the engine and looked again and the crank pulley was wobbling all over the place. The bolt had worked itself loose over probably 250 - 300 miles. I'll have to get it tightened with a impact gun like I did last time. There is only so much you can do with a two foot breaker bar. My original crank pulley never came loose after it was hit with the impact gun and I put about 2600 miles on that one. Thanks for the replies! Have a good weekend.
Justin
Old May 17, 2003 | 08:22 AM
StalkerLS1's Avatar
I seriously doubt your impact will torque the bolt to the required 240-250ft lbs. You might plan on having the bolt losen up on ya again.
Old May 18, 2003 | 08:49 AM
White_Hawk's Avatar
Are you using a stock tensioner? Ka-tech makes a solidtensioner that take care of a lot of belt jumping.
-Geoff
