project last head gaskets evarr!
#81
we are sealing that kind of power on std cometics stock size bolts - on nitrous cars. Alot of it like Erik said is in the tuning, and other small stuff those felpros look nice
The guys that are just pushing stuff too hard, will find out when you put a sick gasket or something on it and it takes the head with it if it wants to go vs a gaskets.
I you have 800 hp and gasket problems, its probbaly not really a gasket problem
#82
#83
i was running about 13* 11:1 afr down the track of timing 23# boost
stock replacement arp studs, ls2 block, no filler, no welding, first gen all pro ls heads as cast no welding. 156.5mph on a 3850# car, give or take 1200 horse. these gaskets probably had 20 passes all over 145mph and 5,000 miles on them. um what else, stock ls6 intake, ngk 7173 plugs, mix of 93, 110 unleaded, and methanol going to the engine
#85
7 Second Club
some info from me
#88
I got the rest of the bits from Erik...still want to try a pair of these gaskets though.
#89
He was on vacation and now at PRI. I know your a real long distance call but i get through to him most of the time on the phone.
Anyway, mine will come with the cam when it's done..
#90
some info from me
My car has 11* of timing
Stock size ARP's
Iron block
ETP's
Same head gaskets for 2 1/2 years with zero issues (Cometic MLS)
C16
AR 3933's
Maybe try taking some timing out and see if it helps.
What thickness are the new gaskets? What is your Quench?
Got any new plans for next year?
