LTRIM adjust for new Procharger setup
2000 Firehawk M6
ATI D1-SC Procharger (8# tuner kit)
Walbro GSS340 Intank pump
Billet fuel rails and new -6AN braided fuel line
Aeromotive Boost referenced FPR
FLP LT headers w/ off-road pipes
42# SVO injecters
Current IFR is set to flat 5.51 across the board.
After doing some logging on ATAP I'm finding that at Idle my Ltrms are at about (-5.5) - (-12.7) but tend to hover around (-11.7). In doing partial throttle runs I tried to keep my TPS as close to 18% as possible. My ltrms tend to be in the 0.8 - 4.7 but tend to hover around 2.3.
So what do I need to do to correct these ltrms?
Thanks guys,
BH
Dd you have your ltrims set before putting it on? I noticed a 10% increase in ltrims at part throttle, due to the pcv setup.
BH
Someone mentioned that I shouldn't mess with the MAF table if I have a stock MAF. I ditched the GMAF, and descreened my stocker and am using that with the new Prochrager setup.
I would think descreening the stock MAF wouldn't throw it too far out of whack. Or is it something else all together? Let me know what you think.
BH
Click on the "Tech" Section.
I have written it up at link item:
"9. My Approach to Fuel Tuning with LS1-Edit"
I just had to type something similar out one too many times.
Differing views are welcome.
BH
I average LTFT's for each fuel trim cell. Given that level of detail, you
have to decide which fuel trim cell to base your change on (each has a
different purpose and is selected by rpm & load). Since, as you point out,
the fuel trim cells that invoke PE (3, 7, 11, 12, 13, 14, 15, & 22), will go
to zero if LTFT's are negative, using average values in those cells would
misrepresent the LTFT prior to PE mode.
Since we are after high load performance, I based my tuning on using the
highest load non-PE cell (cell 10), so I knew the averages would be solid.
Follow-up measurements and dyno have satisfied me that the approach was
sound.
On the few cars I've measured, I've seen no / low load cells (0, 1, 2, 3, 4)that are overly rich after that change, and in my case, I felt some mild
surging while transitioning to these cells...
-Geoff
Thanks for the good info. I was going to send my PCM out for supercharger tuning, but after looking at your web page I feel more confident to try it myself
Den
