oil return idea
was it basically just a tapped plug? Might not work due to it being too small. I would go no smaller than 3/8" and I don't think the plug is that big. Maybe it is...
I tried to get my Canton pan built with the oil returns in the sump and Canton would not build it, because of their experiences with oil return problems. They recommended at the front of the pan behind the windage screen.
Jim
so the oil would be foamy if you came through the drain plug?
Tapping the pan isnt that hard. You can read on here how a lot of people tap it on the car with a drill bit and vaseline
After all:
