Install Of Aps Twin Turbo!!! Kwikss
Old 08-23-2007, 08:12 PM
  #41
KWIKKAR's Avatar
Is it still easier to install the intake last when I get it in the car? didn't work on it today. Work killed me today.
Old 08-24-2007, 03:03 PM
  #42
Black2001z06's Avatar
Looks good dude!
Keep us updated on the pics.
Lemma know if you need someone to build you an engine!
Old 08-24-2007, 03:17 PM
  #43
TNTramair's Avatar
I think its easier installing it while you have it out.
Old 08-24-2007, 03:47 PM
  #44
BLKWS6's Avatar
dropping the engine out of the bottom....yes...it is.......if you doing out of the top...no way...
Old 08-24-2007, 06:46 PM
  #45
KWIKKAR's Avatar
Well I'm fixing to go back out there and put more wrench time in. And yes I may have LME build me an engine while I have it out. Need something good in the $4000 range or less. Will post up more pics tonight. Pulling tank and exhaust, and may do a few other things.
Old 08-25-2007, 05:57 PM
  #46
KWIKKAR's Avatar
Well Last night we dropped the gas tank, removed all the heat shields. Hint on removing Gas tank. Behind the driver rear tire move the plastic fender shield and there is a 10mm bolt that holds the gas tank filler on. you also need to remove the PHRB and the other brace on top and of course the exhaust. Unplug the sencers and you need a fuel line disconnect tool to do the rest, only one needs it other two use two fingers. Also removed the sender out of the tank and getting it boxed up ready to ship out. Will post up pictures later. I'm on the laptop right now.
Old 08-26-2007, 02:26 AM
  #47
z28adiction's Avatar
Wow if you dropped that bad boy out of there in 3 hours for teh first time you should be damn proud of yourselves that job in a dealership pays 14 hours flat rate R&R. That shop is so clean and neat too just how i liek them. I would deffinately go with a forged motor. you might as well get all you can out of that turbo kit, as we all no they are deffinately not cheap lol. Great pics to goodluck ill be watching this thread
Old 08-26-2007, 08:58 AM
  #48
KWIKKAR's Avatar
Well here's the pictures of Friday night.
Old 08-26-2007, 10:32 AM
  #49
MstgKillr's Avatar
Getting the gas tank out is not too bad, I always had a problem getting it back in.
Old 08-26-2007, 10:35 AM
  #50
Pharm0r's Avatar
Definatly subscirbing...have plans for tt when i get back off cruise
Old 08-26-2007, 01:49 PM
  #51
Sixspeed02TA's Avatar
The hardest part of putting the motor back in with the intake on is not breaking the map sensor. It's real easy to crush it against the firewall. I've got small hands, so reaching around the intake is no big deal. I've pretty much memorized where all the vacuum lines are...LOL Be careful not to hang the brake lines when going back in. For god's sake, make a check list for all the ground wires to reconnect. There's nothing worse than being completely finished with everything, then having to chase down that stupid DTC "engine ground poor quality". Or something to that effect.
Old 08-26-2007, 02:25 PM
  #52
NemeSS's Avatar
use a 6.0 block for your forged engine.
just need new rods and forged pistons,studs
good to go
Old 08-26-2007, 02:32 PM
  #53
52172's Avatar
good to go
or save 900 big ones and forge your block thats what I did and I got plenty of power.
Old 08-26-2007, 09:58 PM
  #54
Blown383's Avatar
ttt and subscribing for more info.
-B
Old 08-26-2007, 10:58 PM
  #55
KWIKKAR's Avatar
How do I forge my block for $900bucks??? Sounds to cheap, and the math in my head doesn't add up.????
Old 08-26-2007, 11:44 PM
  #56
Darren P's Avatar
he means the 900 bucks you will spend if you buy a new iron block
Old 08-28-2007, 09:44 PM
  #57
KWIKKAR's Avatar
Ok did some more work last night. I took everything off the K member and got the New one in the mail the same day. I must say first I glad BMR did'nt make this Turbo kit because there Install guide was wrote by a 3rd grader. Brake lines are held on by Zip ties and the guide doesn't really show what to do, I really dont understand it. I took the A arms and power steering rack to work and did a little cleaning on them. So far everthing is going pretty good. Can't wait to get to the install of the kit. Heres the pictures.
Old 08-28-2007, 10:07 PM
  #58
TT-TECH Veteran
Inspector12's Avatar
One quick tip for you if you haven't installed one of the BMR's before. Install A-arms first brake lines then the rack, but when you do the rack install only the pasengerside with the bolt going in from the top and leave it loose. after you get the motor back in you can get the shaft on real easy and install the driverside bolt from the bottom tighten both sides don't worry they are hot nuts and will not back off and if it did the passengerside will keep you steering, and you can still remove the rack without picking the motor up off of the motor mounts for any repairs you might have in the future. Looks good.
Old 09-02-2007, 12:15 PM
  #59
Pharm0r's Avatar
lmfao @ the budlight. Yeah, i can definatly see how that is an intricate tool for this build
Old 09-02-2007, 02:06 PM
  #60
KWIKKAR's Avatar
BudLight is the fuel that I'm using to keep me going. LOL.
Quick Reply: Install Of Aps Twin Turbo!!! Kwikss
