APS TT Kit, Setup
Old Sep 6, 2007 | 03:54 PM
Rubberduck's Avatar
Just a thought Peter, when you are finshed testing your forged motor. Give us the right data on the parts used, and maybe the sponsors in here could make an exact "aps tt forged engine kit" this way the members who has bought the kit can copy your setup an use your pcm map file for the new "forged" engine they are longing for.
Hopefully one of the sponsors in here will act on this, an give us members a very nice price on the "aps tt forged engine kit".
But as I say just a thought
Old Sep 9, 2007 | 06:37 PM
peter@aps's Avatar
No problem to supply you the complete parts list though the tuning map imho would not be practical unless every customer is running the same fuel octane.
Peter
Old Sep 11, 2007 | 04:09 AM
Rubberduck's Avatar
When do you think you will have more data on the forged lsx
Old Sep 11, 2007 | 06:24 PM
peter@aps's Avatar
I'm out of the shop for most of this week on a testing program so I will check on the F body forged engine project when I'm back at the shop next week.............more on this topic then.
Thanks,
Peter
Old Sep 11, 2007 | 08:18 PM
Jake@EPP's Avatar
Thanks,
Peter
Ours is now up and running, buttom up the rear end, slide exhaust on, and time for a SD tune!
Old Sep 11, 2007 | 09:13 PM
peter@aps's Avatar
Nice work Jake................looking forward to seeing your results.
Peter
Old Sep 11, 2007 | 09:40 PM
Jake@EPP's Avatar
Peter
I'll let you know, the large motor makes these things sound like there spooling at idle haha.
Old Sep 12, 2007 | 05:28 PM
peter@aps's Avatar
Lol.............hurry up and get that SD tune finsihed...............I'm really hangin to see the numbers.
Peter
Old Sep 22, 2007 | 04:58 PM
DanDan's Avatar
Hows APS's Forged motor do? Anymore info?
Thanks
Old Sep 22, 2007 | 06:23 PM
BsGreenZ's Avatar
HA HA DanDan i was right lol... you pick up a car for the project yet...
Old Sep 22, 2007 | 06:28 PM
DanDan's Avatar
BSgreenz,
Right about what?
  #32
BsGreenZ's Avatar
what your doing..
Old Sep 22, 2007 | 06:30 PM
  #33
DanDan's Avatar
LOL check your PM's
Old Sep 23, 2007 | 05:36 PM
  #34
peter@aps's Avatar
Thanks
No new news...............just need some time to install the meth system and then retune the engine.
Peter
Old Sep 23, 2007 | 06:53 PM
  #35
njc.corp's Avatar
Cool
[QUOTE=Loboost]
I think it would interesting to see what everyone’s setup is for their APS TT Kits. If anyones willing to share them..
APS TT Kit Setup
Year Make Model: 2005 Pontiac GTO
Engine- Forged 364 inch
Block(CI):LS2
Compression: 9.3666666 to 1
Oiling: LS4 oil pump
Crankshaft: Stock
Connecting Rods: Callies
Pistons: Mahle
Cylinder Heads: Patriot stage II 317 castings 74cc
Camshaft: LPE GT2-3
Rocker Arms: Stock
Intake Manifold: LS2
Ignition/Computer: Stock HP tuners
Exhaust: Fully custom 3 inch with Burns mufflers
Cooling System:Stock
Fuel-
Pump: Twin Walbro 340s
Injectors: Mototron 60s
Rails: Stock modified with 4x -6 AN fittings
Drive train/Transmission-
Transmission: Built 6 speed with viper gearing and forks.
Clutch/Converter: Textralia twin disc
Driveshaft: 1 Piece Diff Techs
Rear Axle: Kaaz
Chassis-
Front Suspension: Starr racing coilovers
Rear Suspension: Starr and Pedders
Brakes: Bears they suck
Performance-
Horsepower: (XXX rwhp) 797RWHP at 17PSI
Torque: (XXX rwtq) 838 RWTQ
Link to dyno video http://videos.streetfire.net/video/2...96017ac13e.htm
very impressive-
Old Sep 24, 2007 | 02:20 PM
  #36
Hugger Z's Avatar
Originally Posted by Hugger Z
APS TT Kit Setup
Year Make Model: 1999 Camaro Z28
Engine-
Block(CI): Stock 346
Compression: Stock
Oiling: Stock
Crankshaft: Stock
Connecting Rods: Stock
Pistons: Stock
Cylinder Heads: Stock
Camshaft: Stock
Rocker Arms: Stock (Upgraded pushrods & Valvesprings)
Intake Manifold: Stock
Exhaust: 3" Y to 4" over the axle to 3" outlets with bullet mufflers in tailpipes.
Cooling System: Stock
Fuel-
Pump: Racetronix in-tank with hotwire kit
Injectors: Motron 60lb flowmatched
Rails: Stock
Transmission: Stock M6
Clutch/Converter: LS7 clutch
Driveshaft: Stock (until next year)
Rear Axle: Stock (until next year)
Chassis-
Front Suspension: BMR K-Member, stock control arms (lowering next year)
Rear Suspension: BMR LCA's (Panhard rod, torque arm, lowering next year)
Brakes: KVR cross drilled fronts, Stock rears but changing to C6 Z06 brakes if wheels arrive in time
Performance-
Horsepower: 508 rwhp
Torque: 513 rwtq
Added in my actual dyno numbers from my kit. It has been a blast to drive so far! Ordered a torque arm relocation bracket as my trans tailshaft seal has started a drip with all this extra torque.
Old Sep 24, 2007 | 04:55 PM
  #37
WS6 John's Avatar
Is the LS7 clutch holding?
Any issues with the clutch?
Old Sep 26, 2007 | 07:46 AM
  #38
Hugger Z's Avatar
So far yes it is holding fine. No issues with the clutch at this time. Over 700 miles on it with the turbo's so far and still counting. Been on the dyno and to the strip and DD'd the rest of the days.
Old Sep 26, 2007 | 09:29 AM
  #39
Fastbird93's Avatar
APS TT Kit Setup
Year Make Model:
Engine-
Block(CI): Stock
Compression: Stock
Oiling: Stock
Crankshaft: Stock
Pistons: Stock
Camshaft: Stock
Rocker Arms: Stock (918 Springs)
Intake Manifold: LS6
Exhaust: Corsa Indy
Cooling System: Stock w/160 T-Stat
ECS Methanol Injection kit
Fuel-
Pump: LG 255
Injectors: Mototron 60#
Rails: Stock
Transmission: T56
Clutch/Converter: Tex OZ700
Driveshaft: Stock
Rear Axle: Stock
Chassis-
Front Suspension: Stock, lowered
Rear Suspension: Stock, lowered
Brakes: Stock
Performance-
Horsepower: 500 rwhp
Torque: 521 rwtq
1/4 Mile: /driver -- 12.28@125.29, 2.24 short time
Dyno Chart
Old Sep 30, 2007 | 09:16 PM
  #40
peter@aps's Avatar
The LS7 clutch is a real nice upgrade for a daily driven twin turbo street car at around 550 rwhp in my experience.............would be great to hear more from you on this clutch issue when you have more miles on your car.
Peter
