STS ?'s
Old Aug 30, 2007 | 09:13 AM
00TurboTA's Avatar
Default STS ?'s
I have the t-60 rear setup and i like it, but one of my friends has the same setup and the school i go to(UTI AZ), has a trans am with the same setup as well, anyways i have heard of the oil return line coming off the coupling that goes into the oil fill cap. I was wondering of any permanent fixes, so i can head off problems before they happen. The guy who is going to tune my car(NicD) said that especially on dyno pulls are they having this problem...Info appreciated.
kurt
Old Aug 30, 2007 | 09:58 AM
NicD's Avatar
7 Second Club
Hey Kurt,
What most the STS guys do that I have seen is to tap the oil pan for the return. I have seen 2 standard STS oil returns just blow off on the rollers and on the street creating a big mess.
Old Aug 30, 2007 | 10:12 AM
zapp168's Avatar
Alot of people do the return into the oil pan, I welded a threaded bung onto the drivers side valve cover on the front lower corner with a 90* adapter. I just did not like the idea of tapping the oil pan. I have had no issues.
Old Aug 30, 2007 | 11:44 AM
Public's Avatar
I've also seen a billet oil fill cap, cant remember where though.
Old Aug 30, 2007 | 12:20 PM
enginjoe's Avatar
Originally Posted by NicD
Hey Kurt,
One of those was mine. It did that time and again. Turns out I had alot of blow-by which makes the STS PCV/oil return system unuseable. I tapped the oil pan without even taking it off the car. It wasn't that hard. It also makes it less likely that the oil drains back into the turbo when your car sits.
Old Aug 31, 2007 | 12:39 AM
00TurboTA's Avatar
Thanks yall I appreciate it, all of ya, and Nic when ever ur not busy just lemme know when u have time to tune new pcm will be here tom. and all other things are gettin fixed.
Old Aug 31, 2007 | 12:54 AM
JAvenger007's Avatar
braided SS line with pressure fitting end going into a billet cap. Shouldn't have any problems there. Also just toss the STS PCV stuff out and run the rear ports to a catch can and vent the front pass port.
Old Aug 31, 2007 | 10:50 AM
00TurboTA's Avatar
Any info on where it find all this stuff?
Old Sep 1, 2007 | 01:02 AM
after thoughts auto has the cap and summit has pretty much everything else.
Old Sep 5, 2007 | 12:24 AM
00TurboTA's Avatar
I went to Afterthoughts and didnt find a billet cap and what other stuff should i get for the complete install? Thanks
Old Sep 5, 2007 | 09:31 AM
justanova's Avatar
bump
Old Sep 5, 2007 | 04:06 PM
Scott(382-$T$)'s Avatar
EPP tap my oil pan after my oil return line came off the oil cap and sprayed my whole engine down with oil. If you go to EPP's website, under project cars , you can see just what they did. I am running a breather on my after market valve covers also.
Old Sep 9, 2007 | 11:51 AM
sorry i meant pfyc.com for the cap
Then just tap it out for at least 3/8" NPT or you could go 1/2" if it fits. Then get an elbow and a quick disconnect. Summit sells everything else you need just go and type in oil hose. Mine is 1/2" (or use at least a -8 AN size)
Check the PCV threads for info on how to set those up. I would resort to a check valve and catch can rather than the STS stuff.
