800HP Project
Old Sep 8, 2007 | 12:49 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Thanks. If the people at A&A corvette are that helpful, I will probably just look up their phone # and ask them next week. These 6klb grocery-getters are hell on drivetrains.
Old Sep 8, 2007 | 01:11 AM
Bismarck's Avatar
They are pretty good...
Old Sep 8, 2007 | 08:45 AM
TurboLark's Avatar
Is this being built in Southern California? I saw something like this just yesterday at a shop near by.
Old Sep 8, 2007 | 09:16 AM
chuntington101's Avatar
Originally Posted by Bismarck
You can see teh pics here. The biggest problem has been the heater hoses. The throttle body adapter is way back there and on the opposite side.
I am thinking about relocating the air box to the battery side and movingthe battery there. But according to Whipple, the duct is large enough that I will not see any gain by doing that. They did not supply it as a kit, so they had no incentive to be biased, but I Am still a bit unsure...
Opinions welcome????
You can also see the custom made intercooler radiator. The guy made the fins too fine I think, this was supposed to be a free flowing radiator, so I am not sure if I will need fans behind it. What I hate about fans is the space the center motor wates behind the radiator. But its right against the grill so maybe there will be enough air pressure... ????
Opinions needed again???
looks great mate!!
have you got any pics of the back of the blower on the engine?? be nice to see how you got the intake running forward. have you just made a box at the back of the blower??
thanks
Chris.
Old Sep 8, 2007 | 09:42 AM
Bismarck's Avatar
I will have pics taken from the back, the air box is where the stock is... Behind the blower is just the Throttle body adapter.
Old Mar 15, 2008 | 06:46 PM
Bismarck's Avatar
Well Project is finally done, after 7 months. I will post some pictures soon. Running the Whipple at 12 psi and 12deg of timing until the engine breaks in. Then will go up to 15 psi and 9deg. Will have Meth injection from Snow Perf. installed with an on-demand switch for days when its over 100deg which we get it socal in summer time.
The car hauls A** and the 4L80 is much much better. Had to go through two trannys and two Torque converters. The first tranny, I was chated and felt like a sucker. It was an old standard 4L80 sold to me by speed Engineering. He had sourced it form somwhere else. Cost me $5K, had about 200K miles on it and the wrong output shaft. The first torque converter from RPM Transmissions with 3 clutches, had too high of a stall, 2400. I hate stall converters. So had another one built with 1800 stall and 5 clutches I must admit, I like stock factory converters better, but they are not strong enoung.
The new 4L80 from RPM is MUCH MUCH better. I am happy with it now, but do miss the taller 4L65 4th gear. I may go down to 342 rear from 373s, just need to lower the RPM on the freeway. Turning 2500RPM at 75mph. Its about 500RPM higher than the 4L65.
The 4L80 needs more cooling than the 4L65, but the torque converter has a lot to do it. So two B&M external coolers are ordered. Still need to come up with a cold air intake and swap the battery location.
I must say Andy at A & A Corvette, is an amazing guy. This man knows what he is doing. He is not done until its done right.
I have not floored the car yet. But just getting on it softly here and there and while cruizing is more than even my Eibach suspension can handle. I thought I had enough suspension, but for this much power, I will need more, hope I can find something adjustable.
running 60lb injectors, and the oil presssure is 60psi. The Ron Davis Radiator with a 160 thermostat keeps things pretty cool for the motor which helps keep detonation at bay.
Gas mileage dropped from 14MPG to 10MPG. The motor is now 1000cc bigger, and the tranny has more parasitic loss (4L80) and the 3.3L whipple takes more HP than the 1.8L Magnuson.
By the way I will have the other torque converter for sale. LS7 to 4L80 $600, paid $1000, drove for 5 miles
Will update you with pictures....
Escalade ESV 2006 AWD
Built 4L80 conversion with Billet output shaft and shift kit - deep pan RPM Transmissions
Torque converter with 5 clutches - RPM transmission
upgraded HD AWD transfer case from SS4
Custom made drive shafts
427 cuin, Aluminum Block
8.5:1 ceramic coated pistons
60lb injectors
72cc AFR Heads
Lunati Crank
Eagle rods
6100 RPM shift Point
3.3L Whipple Supercharger with 10 rib pulley set 12psi - Max Limit 25psi
60lb injectors
Large Ron Davis Capacity Radiator
Large Capacity Intercooler from Ron Davis
long Headers - REMOVED --- went with shorties and kept stock Y tubes
High flow Cats - REMOVED
Corsa Touring Exhaust - REMOVED Way too loud. Stock exhaust is good enough
Brembo 8 Piston calipers Front & 4 piston Calipers Rear
Eibach Suspension all around 2/1 drop with HD stablizer bars
Widened rims (20x11) 325/50VR20 TOYOs
Old Mar 15, 2008 | 09:56 PM
Reject's Avatar
oh you so need to make some videos of this bad boy
Old Mar 15, 2008 | 09:59 PM
Bismarck's Avatar
I will post more pics... not sure what kind of video I can shoot.
Old Mar 15, 2008 | 10:49 PM
gametech's Avatar
Glad to see you got it going. My friend's still hasn't quite got out of the 13's because of transmission issues. The third 4l80 arrived the other day, so we will see how this one holds up. I believe the best pass he got out of it was a 13.2 at SDR with all 4 wheels spinning out of the hole. The trans problems have kept us from bothering with the fuel system yet, so the 42# injectors are maxed at 6k rpm for now.
Old Mar 15, 2008 | 10:55 PM
Bismarck's Avatar
What is the car and weight?
How much HP?
what is breaking in the 4L80?
Where did you get the tranny?
Old Mar 15, 2008 | 11:03 PM
ls1leadfoot's Avatar
wow....a lot to be taken outta tha bank to complete that build
hope you have patience
Old Mar 15, 2008 | 11:09 PM
  #32
gametech's Avatar
How much HP?
I edited my above post because it is actually the 3rd 4l80 that we are soon to install. This is the turboed Escalade I mentioned in previous posts. It has a Detroit speedworks (livernois) kit with a single gt67 and an '02+ls6 cam that was laying around the garage along with 42# injectors. The original 4l65 didn't have a chance. The second fully built 4l65 broke the output shaft. The first speed engineering 4l80 broke the output shaft (it was supposed to be a custom hardened shaft, but was really a turned down stock 4l80 shaft). The second 4l80 from performance automotive expired from unknown causes that led to slippage in OD while easy cruising on the interstate. BTW, they had kick-*** customer service and promptly shipped the replacement which is soon to go in. I don't have a clue what the actual torque and HP #'s are, because we only have a 2wd dyno.
Old Mar 16, 2008 | 12:13 AM
  #33
Rickys S/C Z28's Avatar
wow man bad ***!
Old Mar 16, 2008 | 10:46 AM
  #34
Bismarck's Avatar
My first 4L80 from Speed Engineering was junked, used with burned parts in with about 200K miles on it. The torque converter was totally screwed up, the first block was honed out of round. I had my share of troubles.
I am very pelased with the 4L80 from RPM, TJ was most helpful. I took out the shift kit as it shifted way too hard. Lingenfelter has good luck with the 4L65s.
Old Mar 16, 2008 | 01:52 PM
  #35
Slowhawk's Avatar
LS1Tech Sponsor
Very nice setup.I'm running the 4L80 conversion with a 5 disk 1800rpm stall.Feels like a stock converter which I love.I'll be surprised if those 60lb injectors can hold the fuel demand of 7-800rwhp in a 6500lb vehicle.My 60's have hit 90% on my small setup.
Old Mar 16, 2008 | 01:57 PM
  #36
Frost's Avatar
.... I took out the shift kit as it shifted way too hard. ......
Sure it's made to go behind a stall, not a stock converter.
Awesome project, awesome setup.
Old Mar 16, 2008 | 05:03 PM
  #37
Bismarck's Avatar
Who did you get your converter from. I am still not happy with the converter. Even though its suppose to lock up in 3rd and 4th, even on freeway at 80mph, when I gas the car, the rpm goes up by 500 or so. It lockes, releases, just not consitant. Did not at all have this problem with the stock converter.
Old Mar 16, 2008 | 05:17 PM
  #38
DeltaT's Avatar
That might be a programming issue - worth checking.
Badass project - how do you like the Whipple 3.3 so far? I just got mine.
Jim
Old Mar 16, 2008 | 05:23 PM
  #39
Slowhawk's Avatar
LS1Tech Sponsor
I also run a shift kit wit hthe built tranny.Was hard as hell in the biggining.I actually lowered the line pressure which helped alot.Shifts tight at part throttle and chirps all gears at WOT. The 4l80 tranny program leaves alot to be disired.Took me almost a month to get it where I like it.
Old Mar 16, 2008 | 05:42 PM
  #40
Bismarck's Avatar
Man, the intake charge temperature is freaking high on the thing. Other than that, make sure you get the correct tensioner setup.
