8.0to1 CR on a 370 and your thoughts please!!
Originally Posted by Turbo LS1 SS
kyle i'm assuming your last setup only saw race gas? my bottom end will be much like your last one if i go with the 15cc pistons, only i dont have as much turbo, probably 750-800w max and is just a street warrior. i just have this problem with a lead foot
No my last set-up ran on pump 93..... and race gas at the track....
Drove the car as a D/D for 9 months straight all thru last summer and winter here.
Did it because i had to.
The wife and I went to toal different directions for work.
45 miles round trip every day.
100+ miles on the weekends.
I would run about 14-15 psi on pump on the street.
Was a blast...... just drank fuel like it was going out of style LOL
Now the new motor....
It can be ran on pump gas to drive on the street..... like almost any of these cars could..... now im staying out of the Boost..... thats where ya get into trouble....
Prob wont do it much......
Its time to get a lil more serious
Kyle
Originally Posted by NemeSS
i dont think you will have too much of a prob. spooling the t76 with a
370ci 8:1 scr, what cam are u going with? 12-15psi should not be a prob. with
pump.
how much preparation is done to your block?,
gaskets?
my build is similar to yours engine wise, but im going tt
62-1 t4 tnetics, 370ci, part fill block,
6.0 h beams, stock crank, 1.425ch pistons 23cc dish
317 heads
pump.
gaskets?
317 heads
lets put it this way IM paying 1200 for preperation and assembling the short block...Im going to pay more to balance the rods and pisstons and crank soon. the reason im going 8 to 1 is because I had the pistons and rods and crank from an old block.
As far as a cam goes I will be calling cam motion to spec me one out. Im assuming it will be rather small. reverse split 220s and 560s lift . I would like more lift then that though. my last cam was 218 214 564 546 on 115 and went 10.2 on 9 pounds cam worked great haha with the motor
224/222 .581/.581 on a 114+2
Kyle
Kyle
You had enough power before.... you just need to learn how to drive What size turbo are you stepping up to now?
I should have it in my hands next week.
Its a new one im testing.
Swapping to an A2W set-up and going with BS3.
I hear ya about the driving....
I need more seat time for sure......
Since the last motor was crap..
They coated the piston skirts instead of ordering new pistons.... the pistoned moved in the bore to much..... stock crank was flexing.....
So a lil more cubes and some O-ringed heads with copper gaskets....
Id like to hit the Cage Cert.
Whats up with your BEAST
Kyle
Something around the size of a GT-55 but better LOL
Kyle
Kyle
Originally Posted by ninetres
Copper gaskets? The ohio boys seem to run GM MLS gaskets with o-ringed heads and no grooves. Why are you leaning towards copper?
It will be a double O-Ring set-up with copper gaskets......
As of now we dont even have any results on how the 6 bolt stuff is doing under extreme Boost.
i keep pushing coolent and im not even at the power you ******* are at.... and thats with studs, AFRs, and a straight iron deck, with GM MLS. low timing as well. wtf
i'd push water boosting down the street with 15psi and 16*, but thats on 93 pump. i think i need to make a better overflow setup, but obviously thats not the cause of my problems.... my headgaskets were poop the past two teardowns
assuming you have an aftermarket overflow, is it a sealed setup, or is there a vent-hole/breather? my jaz had a pinhole last year, and when i'd beat on it, coolant would **** out of there... i sealed it this year (probably not a wise decision)... regardless, i was constantly down about 12oz, and it wasnt going into my oil. i WAS getting oil in my coolent
#34
8.1:1 compression
347"
6.0 mls
intercooled
18 degrees
19 psi
93 octane
spins tires
2years running
http://video.ls1tech.com/video/1aae1...1e018124aa.htm
347"
6.0 mls
intercooled
18 degrees
19 psi
93 octane
spins tires
2years running
#36
If your sticking to pump gas and the street then stick with it....
If its more of a race set-up id go higher.....
The bump in compression really helps out....
My new motor is going from 8.87:1 to 9.5:1 , but ill be on race gas all the time so im not worried about pump gas.
Kyle
Kyle
