My own '99 Hugger Orange Z28 is finally getting put back together!
#102
I just read through your whole build. Sounds like a sweet set-up you got going there. Im sure that thing is going to haul some major *** for you guys. It also looked like you were having good luck with the stock ls1 in there. Good luck at the shootout.
#107
The converter's definately a problem. No matter what we did, take timing out, add more timing, fuel, etc, the car would run 138-139 mph every run. It's going through at 7200 rpm to boot.
It didn't help that Muncie had stones on the starting line.
Thanks everyone for the positive comments, we appreciate it! Bob
#109
Thats a lot of rpm for 140mph if it has a 3.70 gear, 60 foot must have been a little off too but not that bad for the first time out.
Just going to run it as-is or try to swap the converter out before the shootout?
#110
I'm going to try to find another converter Monday, hopefully. Bob
#111
The track was in bad shape tonight, it had a lot of street rubber on it mixed in with gravel! We were surprised when the front end came up on one of the runs. The car was also breaking loose pretty bad in 3rd gear. Bob
#113
ATI can have one out the door in 24 hours, had mine in 3 days. No complaints here and not that expensive really.
Prep will be great in Memphis so no worries about breaking loose in high gear there.
#114
Thats good to know about ATI and about Memphis as well. There's just something about needing to use a scoop shovel on the starting line that just doesn't sit well with me...lol Bob
#115
I'm sure if you can get it quicker if you overnight it, I have had a few converters in here and the ATI has always worked the best. I'm using an 8" 5500 and 7250 = 151mph with a 3.70 and 28" tires.
Thats how the tracks are here, gravel pits so all the gravel gets drug up to the line, I'm kinda used to it by now
#116
#117
Plenty of other good converters out there as well, getting a custom made one quick is the hard part. Either way 9.80s and 140 first time out is pretty good, only one way to find out if everything is right and now you know. Good job getting it cranked out so quick.
#118
wow!! bob the car is comming along great!! sorry im so far behind very very lill time on thr net right knoe.. but ill be all cought up in about 7 days if you know what i mean!!
#119
TyTy its 9.2:1
Kevin its got the 325 with a 3:70
Its funny that we mad 5 runs making 633 nothing more nothing less and No matter what kind of screwed up pass we made it went 138 in the traps (we made nasty looking passes)We think monday I will put In a buddys 9'' continental and test it down in Memphis Thurs. Good thing is the Tune up is good and nothing fell off the car
#120
TyTy its 9.2:1
