Thanks Canada !
9.02 is so close it would **** me off.
Its a good, solid 9.50-9.20 car and anything better than that is just gravy IMO.
Stevie, I'm still using the EPP 232/240 115, I'm going through the traps at 7250 and its still pulling pretty hard.
Jerry, I dont know lol, my wife takes the vids. This camera has the image stabilization stuff, I guess that helps. My old camera would never stay in focus at nigh but this one does a pretty good job. Track prep was great, no complaints there, like I said I'm just so close everything needed to be just perfect - sometimes it happens, sometimes it doesnt. If I go to SDR it will just be in D1SC/9.50 mode so prep wont matter.
Tom, yea I'd say the F1A is a good for a couple tenths/mph at least. My 100.00 intercooler isnt handling it very well. With a bigger A2A or big A2A it would pick up a bit more.
David, I wore out a set of MT 325/50 drag radials trying to get them to work right. I dont want to change the setup too much just to run them, I did run 5.86 in the 1/8 with 275/60s last year so I know they can work. I really dont see any benefit using them since around here MT radials put you in the 'slick' class anyways. I'd likr to run radial slicks but they are all 30" or so. Bowling green is open until Thanksgiving, several other tracks around are open all year around here so thats when I like to race - I hate hot weather.
BLWN1, I could put an FiC on it which is bigger. I'm not even close to maxing out the F1A though but an F1C (or F1R) would be a fairly large step up from what I'm using.
Relatively "cheap" and not a lot of elbow grease involved.
Thanks Sean, you will be close soon yourself if you spend some time on it.
Bigger a to a won't make much of a difference....now an a to w properly sized will have less pressure drop and packed with ice.......
C16 is overkill on the tune I'm running really but I'm just paranoid.I agree Tom, just not sure I want the extra weight or the extra work of an A2W right now.
Kevin, if you want a set of these 96 lb injectors, I'll make you a great deal on them. Bob
