procharger question
Old Sep 20, 2007 | 09:26 PM
Fast_94_Z's Avatar
Default procharger question
well for all of you that are running pro chargers tell me whats going to be my best bet. im thinking of 2 setups. i want to fun either an f1 setup or d-1sc setup on my lt1. would it be better to run a front mount intercooler or the twin highflows that run with the kit. i really dont want to cut away the bumper but if its going to benefit that much the its a small price to pay. im not looking for a full out race car tho. im not looking for a full out race car, just something thats gunna scream and make the car faster. also if you have any pics of your procharger setups please post um.
Old Sep 20, 2007 | 10:53 PM
02NBMFormula's Avatar
unless you have a built big cube motor, the d1sc will be fine.
i went with the front mount because i didnt like all the extra piping on the twin intercoolers. you will have to cut some stuff to make the front mount work.
what are you mods also?
Old Sep 21, 2007 | 04:05 AM
EPP's Avatar
EPP
If you have a stock bottom end or you're not going to run more than 12 psi of boost, the stock twin intercoolers will work just fine. Check out our '95 Formula.
http://www.exoticperformanceplus.com...tCar.php?car=7 Bob
Old Sep 21, 2007 | 07:18 AM
Fast_94_Z's Avatar
well the cars not done yet but it is going tobe completely built.but this is what is going in the car. a one of a kind 427 stroker lt1 engine built to handle up to 25 psi. afr 225 heads, ported intake to match and coverted for the arizona speed mono blade throttle body(1300cfm) bigger cam forgot the size though, milodon oil pan with racing oil pump, nasty performance fuel system with #96 injectors, Meizure elextric water pump. thats pretty much it for the motor. everything for the the suspension is all bmr extreme stuff. as for the bottom end, its going to be a strange 12 bolt with 4:11 gears. i mean its gunna be a fast car but i dont plan on using it for strip only and theres going tobe an onboard computer to monitor everything and tune and adjust as i go.
Old Sep 21, 2007 | 08:20 AM
ls1290's Avatar
Dumb Ass Vette Moderator
Since you have a 427, a D1 will be pushed to its limit feeding it. I would go with a F1-R and a large FMIC. Keeping the F1-R cool with twins will be hard.
Keith
Old Sep 21, 2007 | 08:12 PM
Fast_94_Z's Avatar
well yeah i planned on using a front mount if i went with the f1. does anyone know what i have to do to get an f1 setup for my car because its not a kit? exotic performance plus can you help me out with this and also give me a price quote thanks.
Old Sep 22, 2007 | 02:47 AM
SRZ's Avatar
SRZ
You must be sleeving that LT1 into a 427. Why would you want to put so much stress on that engine w/ 25psi? The engines dont hold together long due to the high piston speed combined with thin cylinder walls. The largest I've seen w/ an LT1 is a 409ci and that was pushing it. You got a BIG wallet.
Old Sep 22, 2007 | 07:56 AM
Fast_94_Z's Avatar
i dont plan on running 25 psi. thats what the motor is going to be be built to handle. im probablly going to run about 15 at the most. i wanted a motor thats able to handle more then im pushing out of it. anyone have info on an f1 setup?
