Truck Manifold guy's Inside????
What gasket's are you all using from the manifold flange to the up pipe flange? The one with 3 bolt hole's in it. I used this new style high temp gasket with a metal insert in the middle and it just spit's them out! Burn's the metal insert into pieces! What gasket work's best for you guy's!
I made a set of gaskets using 1mm thick disk of copper with 4mm dia. holes in it, then put a thick bead of High Temp Silicone Gasket Goop on both sides (holes are used to anchor the silicone). Looks like it will work real good, haven't tried 'em yet.
