Superchargers for dummies
I like were my car is at right now. With a Ls6 intake and a FMIC(frount mount intercooler) Ill be right at 500rwhp. Just make sure you stay at 6-8 lbs of boost no mater what anyone says. Your gonna see post like. "600rwhp on stock bottom end!!!"
You can do it, i can do it, but dont untill your ready.
Cam and headers alone is good for around 400rwhp. Your motor will only handle about 480-500rwhp. 490 is the max i would take it. With your D1sc powers not a problem. You make power very easy. You see my numbers. I can make well over 500rwhp with a cam and a 4inch pully. I dont want that kind of power because i dont want to blow my car up untill i am ready to buy a nice 347 or 402. Besides your drivetrain cant handle 500rwhp-clutch rearend, tires. Your going to need to upgrade alot of stuff to handle 500rwhp, If you dont so it right you will be working on your car alot. Your going to see alot of people with crazy dyno numbers, dont worry about them. Your D1sc can make about 800rwhp(with the right motor and stuff) I see people claiming 500+rwhp with 8lbs of boost and A stock car. You have to understand that all dynos very.... One dyno wil show huge numbers. The other wont. There are lots of shop owners out there that "Hype" their dyno number to get work. Dont worry about anything besides your motor and your money. If you keep it under 500rwhp your motor will last alot longer. A cam will put you over 500rwhp. Even a small one. LS1s love cams.
Upgraded to Steel J Bracket
Upgraded to SDCE 8 Rib Spring Tensioner with 4.0 pulley
Upgraded stock harmonic balancer to ATI Superdampner
Stock ATI 3.5" twin intercoolers
btw you have almost exactly the same set up i have. only other motor mod i have it pacesetter long tubes which are great headers.
* i have belt slip issuses because i have a bad pulley has nothing to do with SDCE*
pacesetters are pretty good headers? i just notice how cheap they are. ive never given them much thought because they are so much cheaper than other brands, so i just naturally think they might have poor workmanship or something.
I made 7.6 lbs of boost.
the bigger the crank pulley the more boost
the smaller the supercharger pulley the more boost.
you will be around 8lbs of boost.
Basicly i think with the right fuel a good tune, headers, and the 4.00 inch pulley you will be fine. Just becareful what else you add. I even stayed away from a ls6 intake because i think it will put me over my goal of staying under 500rwhp.
Im telling you guys how I did things and were i want to be. A supercharger is awesome.
A D1sc is good for way more horsepower the your stock block can handle. All im saying is watch out with a D1sc its not hard to jump from 7lb of boost to 13 lbs of boost. If you do headers Ls6intake and D1sc you will be fine al long as you keep it at or under 8lbs of boost. with a cam you make 400 if you lucky. its hard to not make 500 with a D1sc big difference. you will be ok with a D1sc if you keep it very mild.
Why do you say this? I am the guy that bought 42s at the beginning then I had to step up to 60s. I should have went straight to 60s from the start.
To the OP: Go with 60s injectors from the start and be good for a long time.
If you want to save thousands of dollars on the right parts then stick with Bob at EPP. Don't bother looking elsewhere. I put my life on that!
also, what about magnachargers? anyone have any experiance there?
https://ls1tech.com/forums/dynamometer-results-comparisons/797583-2000-magnacharged-camaro-ss.html
https://ls1tech.com/forums/dynamometer-results-comparisons/783269-02-magnacharged-camaro.html
https://ls1tech.com/forums/dynamometer-results-comparisons/792472-lm-speed-magnusion-kit-02-ws6.html
Let me know if I can answer any questions for you,
Ed
im basically saying i am not going to abuse it and im going to respect it. thats why im doing all this research way before i do it. so when the time comes i know what im looking for
BOSS APPROVED!
