New best MPH
Old Oct 14, 2007 | 09:44 PM
LASTLS1's Avatar
6 Second Club Moderator
Default New best MPH
Finally got the bugs out of the car. Wiring, plug wires, header gaskets leaking, head gaskets leaking, computer not loging, fouling plugs every ten minutes. Anyways you get the picture.
The car spun a little in the 60' 1.42
5.66@130.52
8.66 @163.7
I got the car to hook in the 60' but the track went away at the 660' scary! I got the car to 1.34 after that twice in a row but got loose half track. Not a bad night over all.
Old Oct 14, 2007 | 09:57 PM
NA$TY-TA's Avatar
Sweet man any vids??? You making the LSX race Next YR?? Thats my goal......
Old Oct 14, 2007 | 10:15 PM
LASTLS1's Avatar
Yes, I really wanted to go this year but the car wasn't ready. I still don't have all the safty equiptment either. I will be ready for the next one!!
No vids, it was after dark and I wasn't expecting much after the year I've had.
Old Oct 14, 2007 | 10:22 PM
SSilverSSurfer's Avatar
congrats thats moving the hay
Old Oct 14, 2007 | 10:40 PM
onfire's Avatar
Coal Mining Director
You're flying at +160mph!
Which heads gaskets did you get to work?
Old Oct 14, 2007 | 11:02 PM
LASTLS1's Avatar
Well I went with a different exhaust wheel on the turbos. I think it will be easier on the gaskets.. I'm using titan copper, oring- receiver groove. They were brand new gaskets and I didn't push a drop of water, time will tell. The boost was @ 19 lbs.
Old Oct 14, 2007 | 11:40 PM
Jimmy P's Avatar
I thought that you used those before and didn't like them?
Old Oct 15, 2007 | 12:15 AM
slowredz's Avatar
What kind of power does your car make?
Old Oct 15, 2007 | 12:30 AM
stewie8apie's Avatar
This just gives me more motivation
Congrats!
Old Oct 15, 2007 | 06:55 AM
cablebandit's Avatar
wow thats moving...whats it gonna run when you put the better 60' with it?
Old Oct 15, 2007 | 10:04 AM
LASTLS1's Avatar
Thanks, first I don't think the 60' will get much better than a 1.30-1.32. The car made a little over 900 hp. A far as the gaskets go I don't have a choice at this point, unless I go with a new LSX block! I got the car working good off the line, now I need a little help with the weather (not being too cold) and I'll be ok. I would like the car to run a .50 before I put in away for winter.
Old Oct 15, 2007 | 10:42 AM
LS1 SPEED's Avatar
congrats Andy
Byron Sat ?
Old Oct 15, 2007 | 11:45 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Congrats Andy, you've had a heckuva year and it's great that you finally made a clean hit.
Old Oct 15, 2007 | 12:13 PM
danimal95's Avatar
glad to hear you finally got it sorted out,nice mphalthough i thought Haider said you mentioned to him that your still pushing some water??????
Old Oct 15, 2007 | 12:26 PM
LASTLS1's Avatar
No, I first thought I was, but I'm filling it with water and I don't have an expansion tank to back feed into the radiator. It's a one way shot now. When the engine heats up it spills out some in the over flow tank, maybe 3 or 4 ounces. When I was pushing water before the tank would fill up and then some. You were there when I pushed off my coolant hose from built up pressure in the expansion tank. If the track will hold it Sunday I will up the boost until I loose traction or push water. I'm curious to find out what the limit of the gaskets are, I hope the track is up to the task!
Old Oct 15, 2007 | 12:33 PM
Smokin87TA's Avatar
Restricted User
Congrats man thats flying. It seems like there is still more on the table if everything gets sorted out. Good luck and id love to see the car move out in person.
Old Oct 15, 2007 | 12:35 PM
Websy21's Avatar
**** thats rollin out, congrats, that would be some scary *** **** breaking loose at the speed
Old Oct 15, 2007 | 12:41 PM
LS1Tech Co-Founder
Andy, I was talking to Mike Brown about 'pushing water' and he has really come up with good ideas around that.
Old Oct 15, 2007 | 01:25 PM
camarols1's Avatar
Nice runs!
Any info on the build up of the car? Engine, turbos, cam ...??????
I have similar goals, but with a 3000lb car.
Old Oct 15, 2007 | 06:04 PM
LASTLS1's Avatar
Originally Posted by camarols1
Nice runs!
It's a 408 ci iron block, twin 72's , Speed Inc turbo cam, ET heads, stock intake, Speed Inc headers, air to air, 3425-3450 lbs, 165 lb injectors. That about sums it up. Speed Inc fabricated the kit. I like it, it works well. I just need a little time at the track and I'll get it working good, maybe this weekend?
