forged 347 w/ 9.5:1 & boost?
Old Oct 18, 2007 | 06:24 AM
30th t/a's Avatar
Default forged 347 w/ 9.5:1 & boost?
I know roughly 8 psi is about the most you want on a stock bottom end car without running meth. How much could a person run with a forged bottom end and 9.5:1? running no meth.
Old Oct 18, 2007 | 06:30 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
I'm running 14~15psi on my 9.5:1 forged 347. No problems here. I am using meth now with the F1, but before when I had the P1, I had it maxed out and it would make 14psi without the hat and filter on and no meth. Just make sure your tune is good.
Old Oct 18, 2007 | 06:58 AM
Mr.MartyStone's Avatar
You should be able to get to 15 psi with meth pretty easily. Without meth I wouldn't lean on it as hard.
Marty
Old Oct 18, 2007 | 08:08 AM
trod's Avatar
Intercooled or no intercooler? I would like to know how much boost to run as well? My intercooler is trashed no money for new one right know.
Old Oct 18, 2007 | 08:12 AM
ChevyChad's Avatar
Why anyone would do any sort of FI without an intercooler is beyond me. Seriously, why skimp on an intercooler. Only way I'd not run an IC is if I was only running 4~5#
Old Oct 18, 2007 | 10:04 AM
30th t/a's Avatar
yes Ill have a front mount intercooler. NO METH THOUGH.
Old Oct 18, 2007 | 11:07 AM
Websy21's Avatar
Some poeple run meth as there intercooler, mostly in drag applications. Also at low boost 6-7 psi and meth without an intercooler shouldn't be a problem. Its all in the tune and whatever goals you have.
Old Oct 18, 2007 | 05:07 PM
chriswtx's Avatar
Going to run 15-18psi on mine with meth and large intercooler...
Motor details
347ci, Eagle LS1 6.125" rods, Diamond -8.6 dish pistons, stock crank, new LS6 block, ARP head studs, custom Comp Cam 226/232 116LSA, Texas speed CNC LS6 stage 2.5 heads 2.04in 1.575 ex valves that I took apart and hand finished, Kooks 1 7/8" headers, ECS dual nozzle meth kit, ported Weiand intake, 9.5:1 compression
Old Oct 18, 2007 | 05:58 PM
EPP's Avatar
EPP
We've run 16 psi with our front mount intercooler kit on 93 octane. Bob
Old Oct 30, 2007 | 08:53 PM
Chris'stransam's Avatar
How much boost can a stock motor hold
Old Oct 30, 2007 | 08:58 PM
just bout this 99 TA , and I want to make more power. Where do I start? Well I think it's stock.I've had it at the track it ran 13.4 at 104.9 . Not bad for the first time in the car at the track
Old Oct 31, 2007 | 06:36 AM
black01_WS6's Avatar
Right around 8-10 somewhat reliable- it comes to the tune. I know some people that have run 12-15 but they were/are on limited time.
Old Oct 31, 2007 | 11:48 AM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
+1 Only instances I've seen with big boost were alcohol cars or blow through carb setups.
Old Oct 31, 2007 | 01:18 PM
cablebandit's Avatar
i think it would be better to ask about horsepower instead of boost. I think you can do 700rwhp with a/a i/c and no meth with 93 octane
Old Oct 31, 2007 | 06:48 PM
Got Me SOM's Avatar
I wouldn't run less than 9.5:1 compression. I ran 9:1 and my setup felt a lot sluggish down low as compared to 10:1 compression.
centrifugals like more compression.
Old Nov 1, 2007 | 11:31 PM
NemesisC5's Avatar
Truer words cannot be spoken....I'm running 10.1:1 at 9-10 psi with conservative tune & engine has been very responsive & reliable
Old Nov 2, 2007 | 08:57 AM
SR-71 SS's Avatar
15 psi with fmic on 93 octane and 9.1-9.5 compression
