Venting Crank Case
Old Oct 21, 2007 | 07:30 PM
Kaneman's Avatar
Default Venting Crank Case
I currently just vent both valve covers to a catch can, but since I have the motor out I was wonder if adding an LS6 valley would be worth it to help vent more? I have a T76/81AR and am going to try and get as much boost as I can.
Kane
Old Oct 21, 2007 | 07:37 PM
52172's Avatar
your vent system should work, but you should have some vacume sucking in the catch can. I hooked my catch can up to the inlet on the turbo so it creates vacume.
Old Oct 21, 2007 | 07:54 PM
engineermike's Avatar
Can you swap that .81 for a .96?
Old Oct 21, 2007 | 08:47 PM
52172's Avatar
mike do you really think he needs to swap to the .96 since his is a rearmounted sts? He might have the correct ar?? I just know the rearmounts have a hard time spooling so they are run lower ar's than front mounts.
Old Oct 21, 2007 | 10:15 PM
Didn't realize it was a rearmount. Backpressure will be high either way then.
Edit: Yikes! A 408 with a T-76 rearmount .81 A/R. Backpressure will be through the roof!
Old Oct 21, 2007 | 10:45 PM
Slowhawk's Avatar
LS1Tech Sponsor
A LS6 valley won't hurt.
Old Oct 22, 2007 | 09:56 AM
MECHAM's Avatar
i would get the ls6 valley...408 running more boost...a lil extra way to relieve engine pressure
Old Oct 22, 2007 | 12:53 PM
Zombie's Avatar
I'm running total seal rings, it has pretty much eliminated any pressurization of the crank case I was getting.
