PTK/S kit users, question.
Old Oct 23, 2007 | 08:55 PM
Reject's Avatar
Default PTK/S kit users, question.
On those kits, is the turbo high enough to be gravity drained if plumbing into the oil pan? and you still get to use the stock K-member right?
Also to plum the oil pan do i have to remove the engine or can i take teh pan out with the engine still in the body?
thanks in advance!
Old Oct 23, 2007 | 09:16 PM
Darren P's Avatar
thanks in advance!
yes and yes
I did mine without removing it from the car
but I would reccomend removing the oilpan, which can be done with the engine still in the car
Old Oct 23, 2007 | 09:18 PM
Reject's Avatar
could you give me an idea on how to remove the pan? i tried searching but it's coming up with errors, guessing it's being updated right now.
Old Oct 23, 2007 | 09:20 PM
Darren P's Avatar
you have to drop the K member I think or take the engine mounts loose and jack it up off of the K member
I have never done it myself
do you have a PTK kit or are you looking at one?
Old Oct 23, 2007 | 09:43 PM
Frost's Avatar
There are lots of pics of the kit and what not in the large thread in my signature
Old Oct 23, 2007 | 10:01 PM
PLucas's Avatar
You could have the drain go to the timing chain cover. Easy to remove
Old Oct 24, 2007 | 07:50 AM
Reject's Avatar
hey Frost, on one of your pictures in your sig, do you have yours draining to the timing chain cover? looks like it almost, if so did you have to switch over to a UD pully or was the stock one able to clear it?
i just noticed i had posted in that thread back in 05 lol been a long time but i'm finally going for it!
Old Oct 24, 2007 | 09:27 AM
nossty1's Avatar
I may be having some problem draining my t88 but am not completly sure yet.
I have some smoke at idle but only after I have been driving for a bit.
Old Oct 24, 2007 | 11:02 AM
RW99's Avatar
My T67 drains to the oilpan. Get that exit fitting on the turbo correctly; I had some leaking.
Old Oct 24, 2007 | 09:57 PM
Frost's Avatar
mine drains to the pan. Mine has been on the road solid for a year now at 14.5-18 psi too; knock on wood.
Old Oct 24, 2007 | 10:31 PM
Websy21's Avatar
I got a one of these kits in my garage right now with there a2w intercooler and the turbo upgraded to a 80mm. Kit only has 500miles on it but looks brand new. Can't wait till this winter, will be a fun project. Its going on a 408 too with a viper spec t-56 and moser 9''. I know where to look if I need any answers, I've already checked out your page there frost looks good.
Old Oct 24, 2007 | 10:48 PM
trever phillips's Avatar
I used a angle drill shorten the drill bit to start, then by hand (shorten drill bit in socket) then tapped it the same way, Teflon tape changed oil no leaks. I was going to drop the pan but I tried this first? pan isn't that thick and the hole turn out looking pretty nice
Old Oct 25, 2007 | 03:52 AM
Frost's Avatar
For any PTK guys I will say this.... solid mounts are a MUST; stock or poly will burn up on the driver's side. Seriously.
Old Oct 25, 2007 | 10:09 AM
nossty1's Avatar
I will have to take a look at my motor mounts. So far I have not had any problems.
Old Oct 25, 2007 | 01:54 PM
Darren P's Avatar
same here
mine have been fine
we checked them pretty well when I put the 403 in my car and they were fine then
at that time it had about 9000 miles since the trubo kit had been put on
Old Oct 25, 2007 | 09:10 PM
Reject's Avatar
roughly how many inches do the oil lines need to be? i know the drain will have to be a -10AN size but the feed?
Old Oct 25, 2007 | 09:27 PM
b00sted's Avatar
The feed is usually a -4.
Old Oct 27, 2007 | 07:31 PM
Reject's Avatar
what bracket did everyone use to relocate the alternator? smokinHawk's?
Old Oct 27, 2007 | 08:53 PM
Darren P's Avatar
I tried 2 PTK brackets and ended up making my own
Old Oct 27, 2007 | 11:27 PM
Frost's Avatar
I have a modified PTK bracket, I have to have my factory alternator rebuilt (using the PTK one still) before I can try out my Smokinhawk bracket.
As far as the mount.... I had this "mystery smoking" coming from the driver's side for the longest time, and I couldn't figure out what it was. It was the rubber in the mount. Seems like Countryboy may have had the same happen to him.
