Got the new setup on the dyno
Old Oct 26, 2007 | 10:34 AM
  #41
Tiago's Avatar
Originally Posted by GoldRust
Great numbers tiago. Just remember what I told you about fuel systems. Dont let a cheap 150$ pump hurt your setup. That thing has ALOT of power left in her. Cheers to building a beast
for sure, Im working at it from two angles. Have you guys ran a weldon pump wihtout sumping hte tank? I saw a supra setup with a "syphon" going into the stock tank from the top and it worked well. I was thinking of doing something similar. I will have to go see you guys about some PT76s
thanks guys!
Old Oct 26, 2007 | 10:58 AM
  #42
SSilverSSurfer's Avatar
when I talked to MECHAM about his setup he said he was running 3 pumps and I done believe he was having any problems
Old Oct 26, 2007 | 11:12 AM
  #43
2000 Tran Zam's Avatar
Great numbers Tiago... Sounds like you have a stout combonation... What are ultimate power goals in the end? Your gonna have a hell of a time getting that car to hook, lol.
Congrats though, sounds like you worked your *** off for it!!
Old Oct 26, 2007 | 11:31 AM
  #44
fitz98ta's Avatar
that is truely amazing man. I though what you were doing on a stock cube motor was outstanding, i can't wait to see what happens if you upgrade turbo's.
WOW!!!
good job and luck with the car
Old Oct 26, 2007 | 11:42 AM
  #45
MIGHTYMOUSE's Avatar
lots of supra guys run 3 walbros, i consider them all around a better option than a RACE pump on a STREET car.
next step for me from my 2 walbros would be 1 walbro and one bosch 044 (im on the verge of trying both of these inside the stock tank) i have the pump waiting to try since i knew i coud not fit 3 255's in there.
if that didnt get me where i wanted i would do a pair of 044s but prolly have to buy a fab tank or sump the stocker.
the LAST thing i would do is a weldon or aeromotive on MY car. $.02
Old Oct 26, 2007 | 11:46 AM
  #46
Loboost's Avatar
Originally Posted by Tiago
I'm on my way out of town on business and tomorrow I'll be at the track so when I return on Sunday I'll post the sheet I have. I spent most of the time trying to fix the short and ran out of time before they closed to get all my sheets. I ask to go back and get it.
33 hp per lb of boost is not unheard of for sure. Fuel ran out right where I thought it would. Turbo ran out a little earlier then anticipated lol. It actually took more boost to break 1000 then I figured it would, damn little ebay turbos.
Tiago first off I want to apologize on my choice of words in my first post!!
I really am not trying to put what you have accomplished down, Like I said in the second post I really do not doubt the power potential of your setup and yes 33hp is very realistic I just wanted to see the graph because I have never seen basically 100hp even gains on any set up thats all. I am sure you just rounded the figures off and went off of memory and the actual #s will not be even 100hp spreads thats all. Again my apologies for my bad choice of words and Congrats on your setup and good luck at the track!!!
Les
Old Oct 26, 2007 | 11:47 AM
  #47
Tiago's Avatar
DAvid,
care to elaborate why? The supra guys and viper guys seem to have success with it, when coupled with the controller which is a must.
thanks
Old Oct 26, 2007 | 12:54 PM
  #48
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
A local guy runs 4 walbro 340s or 420s (don't remember the exact ones) on his Ford GT. He's making over 1400 to the wheels.
Old Oct 26, 2007 | 12:56 PM
  #49
fash00's Avatar
Go with a pair of Tc76s
Old Oct 26, 2007 | 02:33 PM
  #50
Frost's Avatar
Man those low boost numbers are incredible!!
I know you said timing was at 18deg, but if you have second.... does that just mean 18 at peak (up top) or are you running a flatlined 18deg through most of the band?
Good job, I bet it's a lot more than a handful.
Old Oct 26, 2007 | 02:43 PM
  #51
JMBLOWNWS6's Avatar
thanks guys!
My weldon(600A) only pushed my last setup to 620 rwhp. Becareful! Now my magnafuel is baller. A little on the loud side (Not as bad as my old weldon) but it flows like a ****
Old Oct 26, 2007 | 02:45 PM
  #52
ddnspider's Avatar
Tiago i forgot to ask,maybe i missed the post,how do you like the faceplated T56 setup?
Old Oct 26, 2007 | 02:46 PM
  #53
JMBLOWNWS6's Avatar
DAvid,
thanks
Mightymouse has always been against big pumps on a street car. Im not sure why, Maybe because they are louder? I for one am SOLD on magnafuel pumps. I driven mine everywhere and it has never locked up or shutdown! You know how hot it gets in TEXAS And you dont have to have a controller for it either
MP-4303 2,000+ 20–120psi 14A@45psi #8AN in and out 7"L x 3"Dia 4.5 lbs.
http://www.magnafuel.com/products/efi/pumps/MP-4301.htm
I got mine from Nasty Nate
Old Oct 26, 2007 | 02:48 PM
  #54
DeltaT's Avatar
Very cool numbers. Props!
Jim
Old Oct 26, 2007 | 04:24 PM
  #55
NA$TY-TA's Avatar
Cograts Tiago. I knew she would be a BEAST
Im not a fan of more then one pump since i had two and one didnt work. Its the whole story of ya didnt know it wasnt working till you needed it.
I know you will get it to work like ya want.
Congrats
Kyle
Old Oct 26, 2007 | 06:08 PM
  #56
Inspector12's Avatar
TT-TECH Veteran
Great results so far for you Tiago!!!!!!!!!! You have more possibilities once you get your fuel worked out with some larger hair dryers on there!
Jeff
Old Oct 27, 2007 | 12:15 AM
  #57
LASTLS1's Avatar
6 Second Club Moderator
Nice numbers! I
I run two A1000's, the second pump on a manual switch. I run the stock fuel tank and the fuel pressure is steady. I have also heard the Magnafuel pumps are the ****! Btw, I've run my aeromotive pumps on the street for 3 years! No problems so far. Andy.
Old Oct 27, 2007 | 07:39 AM
  #58
BlkHwk's Avatar
That thing is a monster. Awesome
What kind of dyno are those #'s from?
Old Oct 27, 2007 | 08:25 AM
  #59
52172's Avatar
Originally Posted by 98turbls1
go twin 88's man... That's totally sick bro... I bet you can easily push it to 1250rwhp once you get the fuel and turbo right...
I think I would get twin st72's then you would have same spool time, but power to take you to 2200 crank.
Old Oct 27, 2007 | 09:06 AM
  #60
I require oem noise levels and reliability
If there are cheaper, more reliable, quieter pumps available that get the job done... WHY put a race pump in?
