Got the new setup on the dyno
Old Oct 29, 2007 | 12:02 PM
  #101
ABeasst's Avatar
I was having the same problem with my line lock yesterday at the track and ended up just heel/toeing it to get a nice big burnout. I am going to rebuild my solenoid (hurst) and also put new rotors/pads/rebuild the calipers and see if it helps.
Old Oct 29, 2007 | 12:51 PM
  #102
MIGHTYMOUSE's Avatar
put your left foot on the brake pedal after you drop the clutch.
i think your traction had to do with the track/prep. it did not look state of the art.
the new tread pattern 18" bfg's do good.
i think the 295 35/18 hooks better than the 315/30 cuz of the sidewall.
i was running them here:
http://home.comcast.net/~mightym0use/1078pump.wmv
Old Oct 29, 2007 | 01:41 PM
  #103
Tiago's Avatar
the track deffinately sucks in the prep department.... but the big tire cars still hook so I will have to get some big tires.
Old Oct 29, 2007 | 02:25 PM
  #104
SSilverSSurfer's Avatar
time for some Bogart RR's.
Old Oct 29, 2007 | 02:44 PM
  #105
Got Me SOM's Avatar
dude why are you wasting your time running on the 18's? you'll never hook with that much power and its dangerous cause you'll spin on the high end and possibly lose control.
Old Oct 29, 2007 | 02:59 PM
  #106
K99Raptor's Avatar
That's what I use to run and I never really had to much of a problem. I just wouldn't feel safe on them with 1000+ hp. I don't know much about why the line lock didn't work though. I didn't have one, so the old violent heel/toe method was used. It's just so freakin hard on the rear brakes.
I'm with you on this one. Get some dedicated slicks. With my pathetic 375 whp, I still would brake the rear loose on a 1-2 shift using the bfg dr's. It was only if the track was cold, but hell, he's running 3 times the amount of power and tq. At least some et streets.
I wouldn't even worry about skinnies up front either. I'm a weeny though. I'd want as much tread on the front as possible to help steer when the back end got loose at 150+ mph. It's not like you don't have the power to make up for the weight.
Old Oct 29, 2007 | 03:37 PM
  #107
LASTLS1's Avatar
6 Second Club Moderator
Old Oct 29, 2007 | 04:08 PM
  #108
Tiago's Avatar
They work well enough on the street Its all I had so I gave it a try... FTL
Old Oct 29, 2007 | 04:10 PM
  #109
Tiago's Avatar
slicks in the back with no skinnies on the front = wall
skinnies are a must with a real race tire.
Old Oct 29, 2007 | 04:11 PM
  #110
Tiago's Avatar
Originally Posted by LASTLS1
Install automatic and = Attachment 108720
hahhah, not yet.... you might win me over someday, but Im not looking for ET only... although it would be nice its not priority.
Old Oct 29, 2007 | 04:25 PM
  #111
K99Raptor's Avatar
REEEAAALLLY. That's good to know. Does it have to do with the way the car feels like it's floating? The stiff front tires throw the whole feel of the car off?
I've never had the power to need slicks and skinnies, but those little tires up front make me nervous.
Old Oct 29, 2007 | 04:36 PM
  #112
MECHAM's Avatar
lots of supra guys run 3 walbros, i consider them all around a better option than a RACE pump on a STREET car.
next step for me from my 2 walbros would be 1 walbro and one bosch 044 (im on the verge of trying both of these inside the stock tank) i have the pump waiting to try since i knew i coud not fit 3 255's in there.
if that didnt get me where i wanted i would do a pair of 044s but prolly have to buy a fab tank or sump the stocker.
the LAST thing i would do is a weldon or aeromotive on MY car. $.02
3 255's do fit in the stock tank...i told u that already..i have 3 in my car..and have been running them like that for awhile.
2 on all the time..and the 3rd on boost to an aero control source...i only have it about 50% power and my fuel supply is more than adequate.
i agree...3 walbros > external race pump. one of the first hp ls1 my shop did the guy had an external pump aero pump 1000x something or another...in the heat of the summer the thing would shut off...would wait for it to cool down..off again. replaced the pump thinking it was bad...new pump did the same thing. he then switch to 2 walbros.
Old Oct 29, 2007 | 05:09 PM
  #113
well **** man lets see em!
Old Oct 29, 2007 | 05:14 PM
  #114
8ALTNG's Avatar
killer numbers man. cant wait to see the video
Old Oct 29, 2007 | 06:47 PM
  #115
pdd's Avatar
pdd
holy **** bro-congrats
Old Oct 29, 2007 | 08:32 PM
  #116
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Originally Posted by red1999z28
Go with GTO spares up front...they look badass and seem to do good, a guy at the LSx shootout was running them!
My friend showed me his and I was pretty impressed. They don't look like a spare at all. They actually look really cool.
Bias ply and radials don't mix. Ask MIGHTYMOUSE about that.
+1
Old Oct 29, 2007 | 09:06 PM
  #117
NemeSS's Avatar
thats some crazy good stuff,
Old Oct 30, 2007 | 10:29 AM
  #118
JJSimon904's Avatar
Good job on the car man! It was insane before, cant wait for a ride next time I'm down your way!!
Old Oct 31, 2007 | 08:53 PM
  #119
Tiago's Avatar
finally getting around to post this graph, only one I have. This was at 18 psi. Shows the curve pretty good.
Old Oct 31, 2007 | 09:44 PM
  #120
ChevyChad's Avatar
8 sec potential, 12 sec slip
Sweet Tiago!! I think that is the first turbo setup I've seen that makes more HP than TQ. Looks like the numbers of a SC car or a huge N/A. I'm not a big turbo guy, so please excuse me if I sound dumb here, but why is that? Is it because the turbos are maxed out???
